Can not Monitor via WMI
mdsupersonic
Post by mdsupersonic »
Hi Nagios support team
I'm trying to connect to my windows server 2012 R2 thorough Nagios WMI but I get an error message. I've followed the steps in tutorial in Nagios XI administrative guide 2 times but still the problem exist.
I've attached a capture from the error message to this topic.
any help would be appreciated.
majid
Re: Can not Monitor via WMI
What version of Nagios XI are you running? Additionally, what version is the plugin and wizard?
mdsupersonic
I've downloaded the lastet Nagios XI from the wbsite which has the wizard inside it.
I've used the link below to download the plugins for Nagios server
wget http://assets.nagios.com/downloads/nagi ... install.py
I think these are the latest versions.
mdsupersonic
wmic_1.3.13_static_64bit.tar.gz
WMI Wizard: 2.04
and the latest version of Nagios XI
The Windows WMI wizard should already be installed on the Nagios XI system so it should of worked for you by default.
Can you login to the XI server, run the following and post the output?
grep VERSION /usr/local/nagios/libexec/check_wmi_plus.pl
wmic -V
mdsupersonic
First Command
our $VERSION=1.60;
our $requires_PRO_VERSION=1.26;
'DateTime::VERSION',0.66,
'Getopt::Long::VERSION',2.38,
'Scalar::Util::VERSION',1.22,
'Number::Format::VERSION',1.73,
'Data::Dumper::VERSION',2.125,
'Config::IniFiles::VERSION',2.58,
'Storable::VERSION',2.22
print "Command Line (v$VERSION): $0 $command_line\n";
print "Net::DNS - $Net::DNS::VERSION\n";
my $tarfile="check_wmi_plus.v$VERSION.tar.gz";
print README "check_wmi_plus v$VERSION\nFor installation details and more downloads see http://www.edcint.co.nz/checkwmiplus\nThe --help output follows - \n\n";
print "Version: $VERSION\n";
printf("%-19s %19s %7s %-10s\n",'MODULE_NAME','INSTALLED VERSION','STATUS','DESIRED_VERSION');
$module_name=~s/::VERSION$//;
if ($VERSION < $requires_version) {
Typical Usage: -H HOSTNAME -u DOMAIN/USER -p PASSWORD -m MODE [-s SUBMODE] [-b BYTEFACTOR] [-w WARN] [-c CRIT] [-a ARG1 ] [-o ARG2] [-3 ARG3] [-4 ARG4] [-A AUTHFILE] [-t TIMEOUT] [-y DELAY] [--namespace WMINAMESPACE] [--extrawmicarg EXTRAWMICARG] [--nodatamode] [--nodataexit NODATAEXIT] [--nodatastring NODATASTRING] [-d] [-z] [--inifile=INIFILE] [--inidir=INIDIR] [--inihelp] [--nokeepstate] [--keepexpiry KEXPIRY] [--keepid KID] [--joinexpiry JEXPIRY] [-v OSVERSION] [--help] [--itexthelp] [--forcewmiccommand] [-icollectusage] [--ishowusage] [--logswitch] [--logkeep] [--logsuffix SUFFIX] [--logshow] [--variablesdisabled] [--forceiniopen] [--forcetruncateoutput LEN]
check_wmi_plus.pl -H HOSTNAME -u DOMAIN/USER -p PASSWORD -m MODE [-s SUBMODE] [-b BYTEFACTOR] [-w WARN] [-c CRIT] [-a ARG1 ] [-o ARG2] [-3 ARG3] [-4 ARG4] [-A AUTHFILE] [-t TIMEOUT] [-y DELAY] [--namespace WMINAMESPACE] [--extrawmicarg EXTRAWMICARG] [--nodatamode] [--nodataexit NODATAEXIT] [--nodatastring NODATASTRING] [-d] [-z] [--inifile=INIFILE] [--inidir=INIDIR] [--inihelp] [--nokeepstate] [--keepexpiry KEXPIRY] [--keepid KID] [--joinexpiry JEXPIRY] [-v OSVERSION] [--help] [--itexthelp] [--forcewmiccommand] [-icollectusage] [--ishowusage] [--logswitch] [--logkeep] [--logsuffix SUFFIX] [--logshow] [--variablesdisabled] [--forceiniopen] [--forcetruncateoutput LEN]
Second Command:
wmic -V
Version 4.0.0tp4-SVN-build-UNKNOWN
Lets run a check_wmi_plus from the command line and see if works for you.
Run this command as root on your Nagios server and post the output.
/usr/local/nagios/libexec/check_wmi_plus.pl -H xxx.xxx.xxx.xxx -u username -p password -m checkcpu
Replace the xxx.xxx.xxx.xxx with the IP address of your remote server and also the username and password.
If you are using a domain username type in the username as domain/username.
