Can Nagios do this ?
soamz
Post by soamz »
Hi, currently Im using Nagios for only ping, means I have added of my 218+ public and private devices, routers, switches in the network and only ping service is being used.
So, if a ping cuts, I know the device is offline and I get the email.
Then we check immediately.
But now I want to get more out of this and I heard, its possible with Nagios.
Can I have usage and traffic graphs stats details for each host each port too ?
Which plugin to install into nagios for that and is the polling less than 1 min possible ?
I use Cacti now and its takes long poll, so it misses a lot of traffic graph.
Let me know, what to do for getting graphs and usage for each host device.
bwallace
Re: Can Nagios do this ?
Post by bwallace »
Nagios can do all of that....
For graphing, trying using PNP for Nagios or nagiosgraph:
https://exchange.nagios.org/directory/A ... os/details
https://exchange.nagios.org/directory/A ... ph/details
I assume you want to monitor bandwidth usage, and the plugins can vary according to type/manufacturer/OS of the device, so as a general starting point I suggest you search our exchange site for a specific router or switch model and go from there.
https://exchange.nagios.org/directory/P ... -Bandwidth
If you have any other questions, it will be more efficient if we focus on a particular device first and go from there, thanks.
soamz
Post by soamz »
bwallace wrote:Nagios can do all of that....
Okay will test now. Lets see.
bwallace
Post by bwallace »
sounds good - keep us posted -
