I want to setup NagiosXI to be accessed through an Apache proxy. The Nagios XI, landing page show up fine but when I click the link to login, the page where you can enter the user credentials doesn't apply the stylesheet. If I actually log in all other pages aren't useable because the stylesheet isn't applied as well.
When I connect using the IP of the server. bypassing the proxy all works fine.
Any ideas?
This is my vhost configuraation
<VirtualHost *:80>
ServerName nagios.xyz.com
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
ErrorLog ${APACHE_LOG_DIR}/error_proxy_NAGIOS.log
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access_proxy.log combined
</VirtualHost>
<VirtualHost *:443>
ProxyPass /icons !
ProxyPass /logs !
SSLEngine on
SSLProxyVerify none
SSLProxyCheckPeerCN off
SSLProxyCheckPeerName off
SSLProxyCheckPeerExpire off
SSLProxyEngine On
SSLCertificateChainFile /etc/apache2/ssl/xyz_intermediate.crt
SSLCertificateFile /etc/apache2/ssl/xyz.com.cer
SSLCertificateKeyFile /etc/apache2/ssl/xyz.com.key
ProxyRequests Off
ProxyPreserveHost On
ProxyPass / http://172.16.250.10:80/
ProxyPassReverse / http://172.16.250.10:80/
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error_proxy_NAGIOS_SSL.log
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access_proxy_SSL.log combined
</VirtualHost>
Mark
