What is the logic in which the Metrics selection tool selects services for display? For instance a lot of the services that show up for CPU are services defined as "Average CPU" but not other "CPU" related services are not showing up.
Also, the date selection doesn't work under the "Graph" tab. When I select 30 days for example it just sites there. Clicking on "Apply" just resets the date selection to 24 hours.
System:
Nagios XI Version : 5.2.5
nwd2ng01.corp.analog.com 2.6.32-504.3.3.el6.x86_64 x86_64
CentOS release 6.6 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:46.0) Gecko/20100101 Firefox/46.0
Server Name: nwd2ng01.corp.analog.com
Server Address: 10.64.52.120
Server Port: 80
Date/Time
PHP Timezone: America/New_York
PHP Time: Mon, 16 May 2016 14:23:55 -0400
System Time: Mon, 16 May 2016 14:23:55 -0400
Nagios XI Data
License ends in: MSTNQS
nagios (pid 7898) is running...
NPCD running (pid 2008).
ndo2db (pid 24620) is running...
CPU Load 15: 13.98
Total Hosts: 594
Total Services: 4105
Function 'get_base_uri' returns: http://nwd2ng01.corp.analog.com/nagiosxi/
Function 'get_base_url' returns: http://nwd2ng01.corp.analog.com/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://nwd2ng01.corp.analog.com/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.043 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.028 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.021 ms
--- localhost ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.021/0.030/0.043/0.011 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2016-05-16 14:23:57-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: "/usr/local/nagiosxi/tmp/ccm_index.tmp"
0K ......... 445M=0s
2016-05-16 14:23:57 (445 MB/s) - "/usr/local/nagiosxi/tmp/ccm_index.tmp" saved [9836]
Network Settings
1: lo: mtu 65536 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether 00:50:56:9f:52:ef brd ff:ff:ff:ff:ff:ff
inet 10.64.52.120/24 brd 10.64.52.255 scope global eth0
inet6 fe80::250:56ff:fe9f:52ef/64 scope link
10.64.52.0/24 dev eth0 proto kernel scope link src 10.64.52.120
169.254.0.0/16 dev eth0 scope link metric 1002
default via 10.64.52.1 dev eth0
