Cannot Delete Downtime by Hostname from CGI
vivekm
Post by vivekm »
Hi
I am using Nagios core 4.x and I can Schedule a downtime for a host using CGI cmd_type=55.
But when I am trying to delete the downtime for a host using following curl cmd it is not working:
curl --silent --show-error  --data cmd_typ=170 --data cmd_mod=2 --data host=myhostname  --data btnSubmit=Commit --insecure http://localhost:80/nagios/cgi-bin/cmd.cgi -u "nagiosadmin:xxxxxxx"
DEL_DOWNTIME_BY_HOST_NAME = 170
The cgi is returning an error "Sorry, but you are not authorized to commit the specified command."
am i missing any argument? The command DEL_DOWNTIME_BY_HOST_NAME works from shell script thought but i want to work it through CGI.
Is there also a way to find downtime_id of a host from CGI so then i can use cmd_type=78 which uses a downtime id?
bwallace
Re: Cannot Delete Downtime by Hostname from CGI
Post by bwallace »
I'm curious about permissions for the following. Could you post the output of these commands?
ls -la /usr/local/nagios/var/rw/nagios.cmd
Also, could you look in /etc/group and note what users are a part of group 'nagioscmd'
Here is what mine looks like, albeit form a very vanilla test set up:
nagioscmd:x:119:nagios,www-data
vivekm
Post by vivekm »
Following is output of your cmds on my nagios Server
vagrant@vagrant-ubuntu-trusty-64:~/tmp$ ls -la /usr/local/nagios/var/rw/nagios.cmd
prw-rw---- 1 nagios nagcmd 0 May 18 10:33 /usr/local/nagios/var/rw/nagios.cmd
total 8
drwxrwsr-x 2 nagios nagcmd 4096 May 18 10:21 .
drwxrwxr-x 5 nagios nagios 4096 May 18 10:42 ..
prw-rw---- 1 nagios nagcmd    0 May 18 10:33 nagios.cmd
srw-rw---- 1 nagios nagcmd    0 May 18 10:21 nagios.qh
in /etc/group
nagcmd:x:1003:nagios,www-data
Can you please specify the exact Core version you are using? There were several releases in the 4.X branch.
