User Modification Report
ecarrasq
Post by ecarrasq »
System Info
Linux Distribution and version?
*Linux version 2.6.18-274.3.1.el5 ([email protected]) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-51)) #1 SMP Tue Sep 6 20:14:03 EDT 2011
CentOS release 5.7 (Final)
32 or 64bit?
32 bit
VMware Image or Manual Install of XI?
VMware Image
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL?
No.
Question/Request
Is there a way to get a full report on any changes made by users in NagiosXi?
Example: If a user modifies the Load values, Memory Usage percentages, Check Periods, Notification Contacts, etc... any change a user does, is there a report I can run to see those changes?
mguthrie
Re: User Modification Report
Post by mguthrie »
There's a generic log in the Core Config Manager->Config Manage Admin->Config Manager Log. It's not terribly detailed, but it's probably the closest thing there is to a change report.
