VMWare check_esx3 output
jacek
Post by jacek »
I've recently updated the check_esx3 plugin (from 0.2 to 0.5) due to some well known errors.
Now the output of the service check says for example: "CHECK_ESX3.PL OK - cpu usage=1207.00 MHz (6.30%)"
instead of the nicer, previous look: "ESX3 OK - cpu usage=1207.00 MHz (6.30%)
Can I somehow correct this?
P.S.
When will the 0.5 plugin be a standard (my Nagios XI image is from this year)? Or when will the wizard start using the new check_vmware_api plugin?
Re: VMWare check_esx3 output
If you want to shorten the output of the plugin, find the following line in the script and comment it out.
shortname => uc($PROGNAME),
That worked for me.
I don't have any information if the plugin will be updated.
jacek
Post by jacek »
Nice, did the trick!
Thank You!
Post by mcapra »
Is it ok if we lock this thread and mark the issue as resolved?
jacek
Post by jacek »
Sure, thanks again!
