Monitoring Engine is NOT Running
riredondo
Post by riredondo »
hello guys,
i have a problem, i don't know what happened. nagios xi is not running due to configuration error. it was running ok before i tried integrating the business process addons with nagios xi. i specifically followed the instructions in Integrating_Nagios_BPA_With_XI.pdf.
for your reference, below is the output from write config files --> check configuration files:
Error: Invalid max_check_attempts value for host 'printer'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/printer.cfg', starting on line 14)
Nagios Core 3.2.3
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 10-03-2010
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/OpenSUSE_snmp.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/printer.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/nagios-snmp-mon.touchgroup.net.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/OpenSUSE_snmp.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/nagios-snmp-mon.touchgroup.net.cfg'...
specs:
-centos 5.5 (final) kernel 2.6 32bit
- Nagios XI 2011R1.7
- clean install
i will highly appreciate it if you can give instructions to troubleshoot this issue. i hope this wont require me to reinstall the nagios from the ground up. thank you in advance.
rose
mguthrie
Re: Monitoring Engine is NOT Running
Post by mguthrie »
This certainly won't require a re-install. Nagios just requires a valid object configuration in order to restart. It's looking like you may just need to specify a "max_check_attempts" value for the host "printer." See the following outline on troubleshooting configuration errors.
http://support.nagios.com/wiki/index.ph ... leshooting
nscott
Post by nscott »
Rose,
Nagios cannot add the host 'printer' because the config contains errors. I'm not sure how you added the host 'printer', but it is definitely the issue. How to work around it is to find the host in the Core Config Manager and add the generic host template to it, and then apply config.
Nicholas Scott
riredondo
Post by riredondo »
hello!
thank you so much for your help, Mr. Scott and mguthrie. you guys really are the best. thanks for bearing with me and my issues. problem solved by adding the printer template on the configuration per Mr. Scott's instructions.
rose
nscott
Post by nscott »
Good to hear it rose!
Nicholas Scott
