WHen I run this from the command line I get this error
# ./check_nrpe -H usmafacil1 -c check_mscs
UNKNOWN: No handler for that command
this is a custom script
on the client side, I already added the vbs script to the script folder and also I edited the config file
Nssclient
Re: Nssclient
It doesn't look like you have external scripts allowed. Take a look at this page.
Former Nagios Employee.
me.
me.
Re: Nssclient
you are right. thanks enable it.
its working now
thank you
close the ticket
its working now
thank you
close the ticket
