SMS alerting
paul.jobb
SMS alerting
Post by paul.jobb »
Hi;
I am looking for a recommendation for a hardware solution for SMS alerting, I had wanted to use the multitech isms server however that product now seems end of life. Currently we are just using email to text but that's not reliable at times and prefer not to use a service since there are dependencies(i.e. internet ). I have a number of nagios servers installed so a gateway that can be shared would be ideal.
Paul
bwallace
Re: SMS alerting
Post by bwallace »
The only Nagios 'recommendation' I am aware of is the SMSEagle modem.
https://exchange.nagios.org/directory/A ... le/details
Hopefully this will work for you, certainly let us know if otherwise, thanks.
eloyd
Cool Title Here
Re: SMS alerting
Post by eloyd »
Basically, any on-site SMS gateway will work. You generally end up sending it data over your local network unless you have a serial/USB connection to a device plugged into your Nagios server. They're all very similar, so let Google be your friend. :)
paul.jobb
Re: SMS alerting
Post by paul.jobb »
yes thank you understood, maybe I posted this in the wrong forum my apologies on that, I guess if anyone had some specific product recommendations or suggestions thats all I was looking for really.
bwallace
Re: SMS alerting
Post by bwallace »
No worries Paul, this was the correct place to post, and thanks again eloyd - I'll go ahead and close this thread now....
