Down time not reflecting in the nagios Tool
rohithroki
Dear Team,
I have schedued down time for one of the server through nagiosadmin user.
How ever eventhough it shows succesfully scheduled down time its not reflecting in the tool with the down time symbol.
Nagios Version 3.5.0
Thanks!!!!!
Thanks!!!!!
- Box293
- Too Basu
Re: Down time not reflecting in the nagios Tool
Can you post your nagios.cfg file please.
rohithroki
attaching nagios.cfg file for your reference.
nagios.cfg- Nagios.cfg file
- (45.05 KiB) Downloaded 297 times
Are you still getting alerts during this downtime?
Former Nagios Employee.
me.
me.
rohithroki
yes i am getting the alerts as the down time is not set on the host.
- Box293
- Too Basu
In an ssh session on your Core server can you:
Then submit a scheduled downtime. Is anything logged in the SSH session?
tail -f /usr/local/nagios/var/nagios.log /var/log/httpd/error_logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
rohithroki
Hi Team,
Now i am facing this not only while setting the down time even if i try to add new service for the existing server which is already being monitored the newely added server is got getting reflected in the tool.
It appears as soon as it is added but disappears after some time.
Kindly help me in fixing the same as it is becoming a big issue now.
RKJ
RKJ
Please run through these instructions, and post the error_log if anything occurs.Box293 wrote:In an ssh session on your Core server can you:
Then submit a scheduled downtime. Is anything logged in the SSH session?Code: Select all
rohithroki
even if i onboard any server also i am unable to view in the nagios portal.
It is getting added succesfully how ever when i serarch for the host it doesnt shows up and some time it appears after 2,3 refresh of the page and again disappears .
Kindly help me in fixing the issue as it has become a problem
Please follow this information.rkennedy wrote:Please run through these instructions, and post the error_log if anything occurs.Box293 wrote:In an ssh session on your Core server can you:
Also, post your entire apache error + access logs - /var/log/httpd/error_log and /var/log/httpd/access_log
