Highcharts modification
Iskon
Post by Iskon »
i was looking around but I haven't found anything useful.
Is there a way to modify highcharts graphs?
e.g. to use line instead of area, or use bar chart or change colors of lines/areas on graph, maybe change labels or units etc?.
Thx.
bwallace
Re: Highcharts modification
Post by bwallace »
This post discusses modifying highcharts https://support.nagios.com/forum/viewto ... =6&t=30799 - begin with the post from 'lgroschen' and review the link to the highcharts page. This should be a good starting point, so let us know if you have any questions after checking it out - thanks -
Iskon
Post by Iskon »
thx,
I saw this post already, but it's referring to custom changes that are not supported and will most likely be lost during xi upgrade.
Is this only option?
ssax
Dreams In Code
Post by ssax »
Currently yes, that is the only option.
The labels/units may be changeable but it's entirely up to what the plugin outputs since the performance data is what builds those graphs.
