Issues Downloading Report
Berto
Post by Berto »
I was asked to get some CPU stats from Nagios and when I try to download the report I generated I get this error:
The requested URL /reports/availability.php was not found on this server.
Not sure what this mean.
--Berto
bwallace
Re: Issues Downloading Report
Post by bwallace »
One of the things that could cause the PDF reports to fail is that the Program URL on the Admin > System Settings screen is not set like below.
http://xxx.xxx.xxx.xxx/nagiosxi/
If /nagiosxi/ is not on the end of the URL, the PDF reports will not work.
Make sure it is set like the example above.
If that checks out, then please run the following in a shell on the Nagios system and post the output.
ll /usr/local/nagiosxi/
ll /usr/local/nagiosxi/html/
ll /usr/local/nagiosxi/html/reports/
Berto
Post by Berto »
Yup my problem was having an improper URL, once I added nagiosxi to the end it worked. Thanks!!!
--Berto
bwallace
Post by bwallace »
Glad to hear it is resolved! I'll go ahead and lock this thread now, thanks.
