i've got this quick question from a problem i can't figure out..
i am having this troubles with the MBhealth exchange plugin (powershell script on NSClient)
i keep getting the notification: NRPE timeout ( 60 seconds). i know sometimes the server is under heavy load so the command can not always be run within the 60 seconds so i wanted to give it a try to put it on a 90 second timeout, but i keep getting the notification: "NRPE 60 second timeout".
here is my nagios command: ( $ARG1$ = 'CEM', $ARG2$ = empty.)
and here is my nsclient.ini file from the exchange server ( i hope it is allowed to post it this way) ( i added it to attachments to!)$USER1$/check_nrpe -H $HOSTADDRESS$ -t 90 -c $ARG1$ $ARG2$
Everywhere i could think off, i changed the timeout to a higher schedule. (and yes i restarted the nsclient services a several times already)
is there anyone who has an idea where else to look?
Thanks in advance.
Martijn.
