Service Check Timed Out (check_as400)
falsuyet
Post by falsuyet »
Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... 1&start=10
In the future, please create a new thread and link to the old one instead of adding on.
Hi All;
i new on this forum, I am having problem with the Check_as400. when i try to verify the LOGIN check to AS400 server, the process stop processing waiting for a taken from the system.
the debug information is:
Logging in...
waiting for screen...
waiting for token IBM CORP...
token received.
sending login information for nagios...
waiting for login to process...
waiting for token ===>...
please, can someone help on this?
thanks in advance.
regards
Fernando
Last edited by scottwilkerson on Tue May 31, 2016 9:34 am, edited 2 times in total.
Reason: split thread
bwallace
Re: Service Check Timed Out (check_as400)
Post by bwallace »
Refer to the post from 'netexpertise' on this thread:
https://support.nagios.com/forum/viewto ... =6&t=25501
--will their solution work for you?
falsuyet
Post by falsuyet »
Hi bewallace;
I performed the change that is described on that poast, but the problem still happend.
This change is to be applied into the Logout process, but the problem that i have is during the login process. Apparently is waiting for some repsond after the login into the AS400
Logout process solution :
I resolved by editing check_as400.java
In the logout function, uncomment
waitReceive(";53H",NONE);
and comment out
waitReceive(LANG.LOGIN_SCREEN,NONE);
There are 2 of them
regards
Can you run the check from the command line with the -D "debug" set and post the output?
bwallace
Post by bwallace »
Also, by any chance is the username longer than 10 characters and are you using an older version of the plugin? See the Notes in the change log here
https://exchange.nagios.org/directory/P ... 00/details
falsuyet
Post by falsuyet »
Hi ;
I tried again with the newest pluging check_as400 1.4.3 version and changed the logout procedure, but the problem still happens.
testing the check with debug, the result is:
Establishing connection to server...done.
Logging in...
token received.
the user has 5 characters and the password has 8 characters.
Apparently the problem is on login procedure.
I really appreciate if someone can help me on this.
regards.
Fernando
Post by Box293 »
I would contact the author of the plugin to request help. We don't have any AS400 systems to test with and seeing as the plugin is on GitHub and was updated this year, it's most likely you'll get the right help from them.
https://github.com/cjt74392/check_as400
falsuyet
Post by falsuyet »
OK,
i will expecting for the answer.
thanks for your help.
regards
Fernando
No problem - I'll leave this open on our end, let us know if you have any further questions about the plugin, or if you hear anything!
