Alerts not triggert
manfredrotzetter
Alerts not triggert
Post by manfredrotzetter »
We have the problem, that alerts are configured and when we "run the alert now" the alert is send correctly to the email address. But then the alert is never checked again. (Last Run never changes)
Parameters:
Check Interfal: 1m
Lookback Period: 5m
Thresholds: 50 2000
Alert Method: Email Users
1 User selectet
Email Template: System Default
Query:
"query":{"filtered":{"query":{"bool":{"should":[{"query_string":{"query":"*"}}]}},"filter":{"bool":{"must":[{"range":{"@timestamp":{"from":1463995550226,"to":1464081950227}}},{"fquery":{"query":{"query_string":{"query":"message:(\"TS Continuity Counter\")"}},"_cache":true}}]}}}}}
Nagios Log Server Version: 1.4.1 (4 Nodes)
What is wrong?
Manfred
hsmith
Agent Smith
Re: Alerts not triggert
Post by hsmith »
Is cron running on your machine?
Former Nagios Employee.
me.
manfredrotzetter
Yes I think.
I have some corn config's for the log rotate /etc/cron.daily and this one are working properly.
Than I have this one: /etc/cron.d/nagioslogserver
On this I have to jobs and i added a 3th one:
# /etc/cron.d/nagioslogserver: crontab fragment for nagioslogserver
* * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
* * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
* * * * * nagios date >> /usr/local/nagioslogserver/var/nagioslogserver_cron.log 2>&1
Log file: /usr/local/nagioslogserver/var/nagioslogserver_cron.log
Wed May 25 09:44:01 CEST 2016
Wed May 25 09:45:01 CEST 2016
Wed May 25 09:46:02 CEST 2016
Wed May 25 09:47:01 CEST 2016
Wed May 25 09:48:01 CEST 2016
Wed May 25 09:49:01 CEST 2016
Wed May 25 09:50:01 CEST 2016
So I think that cron is working. But is it normal, that usr/local/nagioslogserver/var/jobs.log is empty (file modification date is current) ? Or better question, which job is doing the alerting stuff?
Let's check permissions on those jobs and their logfiles, since they will help us troubleshoot once we can get them written to:
ls-l /var/www/html/nagioslogserver/www/index.php
ls -l /usr/local/nagioslogserver/var/poller.log
ls -l /usr/local/nagioslogserver/var/jobs.log
ls -ld /usr/local/nagioslogserver/var/
manfredrotzetter
The output of the 4 commands on the 4 nodes:
[root@sbcc-log-2601 AD+tgdromar]# ls -l /var/www/html/nagioslogserver/www/index.php
-rw-r--r--. 1 root root 6517 May 10 08:21 /var/www/html/nagioslogserver/www/index.php
[root@sbcc-log-2601 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/poller.log
-rwxrwxr-x. 1 nagios nagios 290 May 25 18:47 /usr/local/nagioslogserver/var/poller.log
[root@sbcc-log-2601 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/jobs.log
-rwxrwxr-x. 1 nagios nagios 0 May 25 18:47 /usr/local/nagioslogserver/var/jobs.log
[root@sbcc-log-2601 AD+tgdromar]# ls -ld /usr/local/nagioslogserver/var/
drwxrwxr-x. 2 nagios nagios 4096 May 25 09:51 /usr/local/nagioslogserver/var/
[root@sbcc-log-2602 AD+tgdromar]# ls -l /var/www/html/nagioslogserver/www/index.php
-rw-r--r--. 1 root root 6517 May 10 08:18 /var/www/html/nagioslogserver/www/index.php
[root@sbcc-log-2602 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/poller.log
-rwxrwxr-x. 1 nagios nagios 290 May 25 18:48 /usr/local/nagioslogserver/var/poller.log
[root@sbcc-log-2602 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/jobs.log
-rwxrwxr-x. 1 nagios nagios 0 May 25 18:48 /usr/local/nagioslogserver/var/jobs.log
[root@sbcc-log-2602 AD+tgdromar]# ls -ld /usr/local/nagioslogserver/var/
drwxrwxr-x. 2 nagios nagios 4096 May 25 10:00 /usr/local/nagioslogserver/var/
[root@sbcc-log-2603 AD+tgdromar]# ls -l /var/www/html/nagioslogserver/www/index.php
-rw-r--r--. 1 root root 6517 May 10 08:16 /var/www/html/nagioslogserver/www/index.php
[root@sbcc-log-2603 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/poller.log
-rwxrwxr-x. 1 nagios nagios 290 May 25 18:49 /usr/local/nagioslogserver/var/poller.log
[root@sbcc-log-2603 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/jobs.log
-rwxrwxr-x. 1 nagios nagios 0 May 25 18:49 /usr/local/nagioslogserver/var/jobs.log
[root@sbcc-log-2603 AD+tgdromar]# ls -ld /usr/local/nagioslogserver/var/
[root@sbcc-log-2604 AD+tgdromar]# ls -l /var/www/html/nagioslogserver/www/index.php
-rw-r--r--. 1 root root 6517 May 10 08:14 /var/www/html/nagioslogserver/www/index.php
[root@sbcc-log-2604 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/poller.log
-rwxrwxr-x. 1 nagios nagios 290 May 25 18:50 /usr/local/nagioslogserver/var/poller.log
[root@sbcc-log-2604 AD+tgdromar]# ls -l /usr/local/nagioslogserver/var/jobs.log
-rwxrwxr-x. 1 nagios nagios 0 May 25 18:50 /usr/local/nagioslogserver/var/jobs.log
[root@sbcc-log-2604 AD+tgdromar]# ls -ld /usr/local/nagioslogserver/var/
drwxrwxr-x. 2 nagios nagios 4096 May 25 10:38 /usr/local/nagioslogserver/var/
Reason: Please use [code][/code] tags around terminal output
hsmith
Agent Smith
Post by hsmith »
Can you do this for about 5 minutes, and let us know what the results are?
tail -f /usr/local/nagioslogserver/var/jobs.log
It's normal for this to be empty, because it gets purged every minute.
me.
manfredrotzetter
No jobs :?
Processed 0 node jobs.
Processed 0 global jobs.
hsmith
Agent Smith
Post by hsmith »
Can you go to Administration > System > Command Subsystem and hit the "Reset All Jobs" button, and let me know what happens?
me.
manfredrotzetter
That's it. Now its working fine.
You can close this post.
Thanks a lot.
Post by mcapra »
Glad you were able to find a solution! Closing this up
