Nagios XI Installation Log
DATE: Tue May 24 14:46:09 EDT 2016
DISTRO INFO:
RedHatEnterpriseServer
7.2
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=5.2.8
major=5
minor=2.8
releasedate=2016-05-24
release=519
Error: Package: rrdtool-1.4.9-1.el7.x86_64 (nagiosxi-deps)
Requires: dejavu-lgc-sans-fonts
Error: Package: nagiosxi-deps-el7-5.2.8-1.noarch (/nagiosxi-deps-el7-5.2.8-1.noarch)
Requires: gd-devel
Error: Package: perl-Net-SNMP-6.0.1-7.el7.noarch (epel)
Requires: perl(Crypt::DES)
Requires: php-mbstring
Requires: dejavu-lgc-sans-mono-fonts
Requires: perl-Config-Tiny
Error: Package: perl-Mail-IMAPClient-3.37-1.el7.noarch (epel)
Requires: perl(Parse::RecDescent)
Requires: php-snmp
Error: nagiosxi-deps-el7 conflicts with nrpe-2.15-7.el7.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Can someone assist?
Nagios XI Installation Failed
Re: Nagios XI Installation Failed
[root@ nagiosxi]# yum repolist
Loaded plugins: langpacks, package_upload, product-id, search-disabled-repos, subscription-manager
repo id repo name status
epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 10,052
nagios-base Nagios 31
nagiosxi-deps Nagios XI Dependencies 26
!rhel-7-server-rpms/7Server/x86_64 Red Hat Enterprise Linux 7 Server (RPMs) 10,859
!rhel-7-server-satellite-tools-6.1-rpms/x86_64 Red Hat Satellite Tools 6.1 (for RHEL 7 Server) (RPMs) 83
rpmforge RHEL 7Server - RPMforge.net - dag 245
repolist: 21,296
repolist: 21,296
Can you enable the redhat optional repo, and try once more?
Former Nagios Employee.
me.
me.
- Box293
- Too Basu
The exclamation ! marks at the beginning of these lines indicate that it is having issues contacting these repositories.aulusow wrote:[root@ nagiosxi]# yum repolist
repolist: 21,296
Try
yum clean all
yum repolistAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
[root@ nagiosxi]# yum clean all
Cleaning repos: epel nagios-base nagiosxi-deps rhel-7-server-rpms rhel-7-server-satellite-tools-6.1-rpms rpmforge
Cleaning up everything
epel/x86_64/metalink | 13 kB 00:00:00
epel | 4.3 kB 00:00:00
nagios-base | 1.5 kB 00:00:00
nagiosxi-deps | 1.5 kB 00:00:00
rhel-7-server-rpms | 2.1 kB 00:00:00
rhel-7-server-satellite-tools-6.1-rpms | 2.1 kB 00:00:00
rpmforge | 1.9 kB 00:00:00
(1/11): epel/x86_64/group_gz | 170 kB 00:00:00
(2/11): epel/x86_64/updateinfo | 557 kB 00:00:00
(3/11): nagios-base/primary | 5.4 kB 00:00:00
(4/11): nagiosxi-deps/primary | 9.5 kB 00:00:00
(5/11): rhel-7-server-rpms/7Server/x86_64/group | 588 kB 00:00:00
(6/11): rhel-7-server-rpms/7Server/x86_64/updateinfo | 1.1 MB 00:00:00
(7/11): rhel-7-server-satellite-tools-6.1-rpms/x86_64/updateinfo | 7.6 kB 00:00:00
(8/11): rhel-7-server-satellite-tools-6.1-rpms/x86_64/group | 1.4 kB 00:00:00
(9/11): rhel-7-server-satellite-tools-6.1-rpms/x86_64/primary | 19 kB 00:00:00
(10/11): epel/x86_64/primary_db | 4.1 MB 00:00:00
(11/11): rhel-7-server-rpms/7Server/x86_64/primary | 13 MB 00:00:00
rpmforge/primary_db | 125 kB 00:00:00
nagios-base 31/31
nagiosxi-deps 26/26
rhel-7-server-rpms 10859/10859
rhel-7-server-satellite-tools-6.1-rpms 83/83
repolist: 21,296
It seems the issue is still there. This server is managed by satellite is the issue related to satellite.
nagios-base 31/31
nagiosxi-deps 26/26
repolist: 21,296
It's looking that way. Can you verify the information in those repo files is correct?
me.
me.
I believe so, as @Box293 mentioned -aulusow wrote:[root@ nagiosxi]# yum clean all
nagios-base 31/31
nagiosxi-deps 26/26
repolist: 21,296
Under your RHEL & RHEL Satellite repositories, there is still an exclamation point present -The exclamation ! marks at the beginning of these lines indicate that it is having issues contacting these repositories.
Requires: gd-devel
Requires: php-snmp
yum can be configured to try to resolve such errors by temporarily enabling
disabled repos and searching for missing dependencies.
To enable this functionality please set 'notify_only=0' in /etc/yum/pluginconf.d/search-disabled-repos.conf
Requires: gd-devel
Requires: php-snmp
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
[root@nagiosxi]# yum repolist
epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 10,055
repolist: 21,216
The Red Hat issue is fixed, however the NagiosXI install script still fails with above error. Can you possibly look into it and advise?
Requires: gd-devel
Requires: php-snmp
Requires: gd-devel
Requires: php-snmp
RESULT=1
INSTALLATION ERROR!
repolist: 21,216
Give this a shot.hsmith wrote:Can you enable the redhat optional repo, and try once more?
me.
me.
