Hi Team,
We have monitoring Memory usage parameter of windows server. The window server have just 1GB ram but the Nagios dashboard is showing 4 GB.Can u help me with this.
Memory usage
gselvakumar
Memory usage
Thanks & Regards,
Gomathyshankar Selvakumar
Re: Memory usage
Can you show us the check_command running for it? Off the top of my head, I'm guessing it's aggregating your swap as well, which is normal.
- Box293
- Too Basu
Re: Memory usage
gselvakumar
Re: Memory usage
The command we are using
/usr/local/nagios/libexec/check_nt -H Servrername -s "Passone7" -p 12489 -v MEMUSE -w 80 -c 90
Thanks & Regards,
- Box293
- Too Basu
Re: Memory usage
The article I referenced above is the solution to your problem. check_nt and MEMUSE does not have a way of differentiating the pagefile from the physical memory.
