use API to delete User account
SteveBeauchemin
Post by SteveBeauchemin »
I am trying to use the API to delete a user from Nagios XI.
I can list the user by following the Nagios XI GUI help screen.
curl -XGET "http://localhost/nagiosxi/api/v1/system/user?apikey=[key]&pretty=1"
and the data is listed
            "user_id": "9",
            "username": "blah",
            "name": "blah 2",
            "email": "blah 3 @ xxx.com",
            "enabled": "1"
then, trying to delete
curl -XDELETE "http://localhost/nagiosxi/api/v1/system/user?apikey=[key]&pretty=1&user_id=9"
returns this
    "error": "User with ID  does not exist."
I am logged in to the host using ssh.
The API Key I am using is for the nagiosadmin account.
So, what am I doing wrong?
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: use API to delete User account
I was able to reproduce this, and it seems to be a bug. I've filed a report for it, ID #8634.
MariaDB [nagiosxi]> SELECT * FROM xi_users WHERE user_id="2";
| user_id | username | password                         | name | email   | backend_ticket                                                   | enabled |
|       2 | bob      | 098f6bcd4621d373cade4e832627b4f6 | a    | [email protected] | 9ugftqso6phnnoshp9dk0um63khm584b4kp0cjnhc673t3ik9u87stcsgtik3ks5 |       1 |
1 row in set (0.00 sec)
You have new mail in /var/spool/mail/root
[root@localhost ~]# curl -XDELETE "http://192.168.4.179/nagiosxi/api/v1/system/user?apikey=uui5lt5s&pretty=1&user_id=2"
The developers got back to me, and this is going to be the proper syntax. (the help page is wrong)
[root@localhost ~]# curl -XDELETE "http://192.168.4.179/nagiosxi/api/v1/system/user/2?apikey=uui5lt5s&pretty=1"
Success.Userremoved.
[root@localhost ~]#
SteveBeauchemin
Thanks for the solution.
Much appreciated.
Feel free to close this item.
Steve B
No problem!
Closing this one out.
