updating from nagios XI 2014R2.6 to 2014R2.7
We are trying to update our nagios XI 2014R2.6 to 2014R2.7. As listed in the Backing-Up-And-Restoring-Nagios-XI document we tried to backup, however, the backup failed with the following error.
i# /usr/local/nagiosxi/scripts/backup_xi.sh
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up MySQL databases...
mysqldump: Got error: 144: Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
I'm not sure if we changed the password of nagios db. Can assistance be provided ?
Backing up MRTG...
Backing up NRDP...
Re: updating from nagios XI 2014R2.6 to 2014R2.7
First try running through the steps in this doc, and post any errors that may come about...
https://assets.nagios.com/downloads/nag ... tabase.pdf
Thank you. I will try and report back.
Sounds good, we'll be watching for any updates -
As advised, i fixed the mysql with the script in the document provided. Output attached. It seems that the repairmysql script had fixed the mysql db. However, i get the same error when i run the backupscript after fixing the mysql db.
Backing up MRTG...
Backing up NRDP...
Any suggestions ?
Backing up MRTG...
Backing up NRDP...
Any suggestions ?
Page 2 of the document, has additional steps if you are still seeing "is marked as crashed" errors
Thank you.
myisamchk -r -f nagios_logentries
- recovering (with sort) MyISAM-table 'nagios_logentries'
Data records: 961
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
Backing up MRTG...
Backing up NRDP...
same error. Am i missing something ?
Data records: 961
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
Backing up MRTG...
Backing up NRDP...
If running "myisamchk -r -f nagios_logentries" didn't fix the issue, you could try:
echo 'repair table nagios_logentries use_frm;' | mysql -t -u root -pnagiosxi nagiosBe sure to check out our Knowledgebase for helpful articles and solutions!
Well, it's same even after running the command.
# echo 'repair table nagios_logentries use_frm;' | mysql -t -u root -pnagiosxi nagios
| Table | Op | Msg_type | Msg_text |
| nagios.nagios_logentries | repair | warning | Number of rows changed from 0 to 961 |
| nagios.nagios_logentries | repair | status | OK |
Backing up MRTG...
Backing up NRDP...
Reason: Please use [code][/code] tags around long output
Let's try running this command again:
Next, restart mysql and show the last 50 lines of the mysqld.log.
Is opening a new support ticket in our email ticketing system an option for you?
echo 'repair table nagios_logentries use_frm;' | mysql -t -u root -pnagiosxi nagiosCode: Select all
service mysqld restart
tail -50 /var/log/mysqld.logBe sure to check out our Knowledgebase for helpful articles and solutions!
