CHECK_NRPE: Socket timeout after 10 seconds.
bsivavani
Post by bsivavani »
Hi Team,
I have a Nagios core setup in my environment for monitoring Windows, Linux servers etc.
Recently i have configured a physical and swap memory monitoring using the plugin ./check_nrpe. But if i run the command i'm getting the error 'CHECK_NRPE: Socket timeout after 10 seconds.'
When i tried executing the plugin without the command and only with IP address as below also giving the same error.
[root@serverlibexec]# ./check_nrpe -H xx.xx.xx.xx
Then i tried increasing the timeout value to maximum of 1000 using -t option which throws the same error :(
Kindly help me in resolving the same.
Thank you
bsivavani
Re: CHECK_NRPE: Socket timeout after 10 seconds.
Post by bsivavani »
Hi Team,
Someone please help me in resolving the issue :? :roll: :(
Post by Box293 »
What agent are you running on the remote servers?
Have you followed the NRPE Troubleshooting Guide?
https://assets.nagios.com/downloads/nag ... utions.pdf
bsivavani
Post by bsivavani »
I'm running Nsclient on the remote server. Also i have tried the troubleshooting methods given in the Nagios documents as well. No luck :cry: What else could be the reason?
Post by Box293 »
Can you show us what steps you followed in the guide, What commands did you type and what output did they produce?
