Installation problem of NA with XI on Centos7
CZ-MY
Post by CZ-MY »
Dear Support,
trying out XI Enterprise and wanted to also install NA. The NA .\fullinstall script is stopping at making the RRD. Extract from log below. The total log also attached. Hope anyone can help me to get my evaluation up.
Thx. Chris
-- Tobi Oetiker <[email protected]>
make all-recursive
make[1]: Entering directory `/tmp/nagiosna/rrdtool-1.4.9'
Making all in po
make[2]: Entering directory `/tmp/nagiosna/rrdtool-1.4.9/po'
make[2]: Leaving directory `/tmp/nagiosna/rrdtool-1.4.9/po'
Making all in src
make[2]: Entering directory `/tmp/nagiosna/rrdtool-1.4.9/src'
GEN librrd.sym
CCLD librrd.la
CCLD librrd_th.la
CCLD rrdtool
CCLD rrdcached
/bin/ld: rrdcached-rrd_daemon.o: undefined reference to symbol 'eval_client'
/bin/ld: note: 'eval_client' is defined in DSO /lib64/libwrap.so.0 so try adding it to the linker command line
/lib64/libwrap.so.0: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [rrdcached] Error 1
make[2]: Leaving directory `/tmp/nagiosna/rrdtool-1.4.9/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/nagiosna/rrdtool-1.4.9'
make: *** [all] Error 2
INSTALLATION ERROR!
Re: Installation problem of NA with XI on Centos7
Just to clarify - are you trying to install NNA on the same server as XI?
CZ-MY
Post by CZ-MY »
Yes. Just for testing.
This is not going to be supported, both of them will need to be on their own isolated machine.
eloyd
Cool Title Here
Post by eloyd »
To go a step farther, all Nagios software is best installed on their own machines. So NXI, NLS, NNA, Fusion, NIM, and Reactor work best if they're on six separate boxes.
Thanks @eloyd!
@CZ-MY - let us know if you have any further questions.
