No XML, RRD is generated after deleting them
wrkilu
Post by wrkilu »
I have Nagios Core 3. I wanted to create some graph from the begening so I deleted simply .xml and .rrd files from /var/lib/pnp4nagios/perfdata/hostname/. And now even despite restarts of Nagios and Pnp4nagios newones .XML and .rrd aren't created :(. What mistake I've done ?
wrkilu
Re: No XML, RRD is generated after deleting them
What are the permissions on the folder, and sub-folders?
