check_nrpe unexpected result with powershell script
sc00354007
Post by sc00354007 »
Hi All,
I am trying to run a powershell script via NSClient using check_nrpe but it is giving unexpected output. The powershell script is fetching a performance counter from list of servers and based on it the result is send to Nagios.
Below is the software version I am using:
Nagios 3.5.1
Nagios-plugins 2.0.3
NRPE Version - 2.15
NSClient - 0.4.1.90
NSClient.ini:
alias_check_scripts = powershell\\check_scripts.ps1
alias_check_scripts = cmd /c echo \\scripts\\powershell\\check_scripts.ps1 ; exit($lastexitcode) | powershell.exe -command -
***********************check_scripts.ps1***********************************
$returnStateOK =0
$returnStateWarning =1
$returnStateCritical =2
$returnStateUnknown =3
$servers = "ABCWPMBX1-ABC","GHIWPMBX3-DEF","DEFWPMBX2-ABC","KLMWPMBX4-DEF","PQRWVJAR2-DEF"
$ErrorActionPreference = 'Stop'
foreach ( $s in $servers )
try
$c = Get-Counter -ComputerName $s -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName
catch
continue
if($c -Match "MSExchangeIS" )
		$errorString = "MSExchangeIS counter is enabled for " + $s
		Write-Host "Critical:"$errorString""
		break
		exit $returnStateCritical
		$errorString = "MSExchangeIS counter is disabled"
		Write-Host "OK:"$errorString""
		exit $returnStateOK
Powershell
PS C:\Program Files\NSClient++\scripts\powershell> .\check_scripts.ps1
Critical: MSExchangeIS counter is enabled for PQRWVJAR2-DEF
CMD
C:\>cmd /c echo C:\"Program Files"\NSClient++\scripts\powershell\check_scripts.ps1 ; exit($lastexitcode) | powershell.exe -command -
Critical: MSExchangeIS counter is enabled for SCHWVJAR52-USB.collaboration.lcl
check_nrpe
[nagios@abc ~]$ /usr/lib64/nagios/plugins/check_nrpe -H x.x.x.x -c alias_check_scripts
OK: MSExchangeIS counter is disabled
Please advise where I am going wrong.
sc00354007
Re: check_nrpe unexpected result with powershell script
I also displayed the value of $c outside the loop while calling from check_nrpe and it is blank.
Why is the value of $c as blank when calling via check_nrpe ?
If I call it from Powershell console or cmd, $c = MSExchangeIS
Can anyone help or point me to the right direction ?
Post by Box293 »
Try changing this:
sc00354007 wrote:NSClient.ini:
To this:
alias_check_scripts = cmd /c echo scripts\powershell\check_scripts.ps1 ; exit($lastexitcode) | powershell.exe -command -
Notice I completely removed one of them and adjusted the other.
sc00354007
Thanks for your response.
I did the changes suggested by you and restarted NSCleint service.
Still the same output.
Could there be an issue with the powershell or the NSClient version itself ?
Can you run the following command on your nagios server (from within the plugins directory), and show the output?
./check_nrpe -H <client ip> -c alias_check_script
Also, post the nsclient.log.
sc00354007
If I run it from the Powershell console, it gives me below output:
PS C:\Program Files\NSClient++\scripts\emas>
Below is the NSClient.log:
016-06-01 08:55:40: d:..\..\..\trunk\service\NSClient++.cpp:1361: Starting: DONE
2016-06-01 08:55:47: d:D:\source\nscp\trunk\include\nrpe/server/protocol.hpp:66: Accepting connection from: ::ffff:x.x.x.x
2016-06-01 08:55:47: d:..\..\..\trunk\service\NSClient++.cpp:960: Injecting: alias_...
2016-06-01 08:55:47: d:..\..\..\..\trunk\modules\CheckExternalScripts\CheckExternalScripts.cpp:257: Arguments: /c echo scripts\powershell\check_scripts.ps1 ; exit($lastexitcode) | powershell.exe -command -
2016-06-01 08:55:47: d:..\..\..\trunk\service\NSClient++.cpp:985: Result alias_check_scripts: OK
$c = (Get-Counter -ComputerName $s -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName)
I also tried printing the value of $c while calling the script from check_nrpe and the value is blank whereas one of the server is giving MSExchangeIS.
Does check_nrpe does not understand the "-ea stop" option ?
ssax
Dreams In Code
Post by ssax »
Please try this code change and see if it works for you.
$commandString = "Get-Counter -ComputerName $s -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName"
Write-Host $commandString
$c = Invoke-Expression $commandString
Please post the output.
sc00354007
Please see below:
Updated code :
$returnStateOK =0
try
write-host $commandString
catch
continue
      break
      exit $returnStateOK
Below is the output when I execute it from the Nagios via check_nrpe:
Get-Counter -ComputerName ABCWPMBX1-ABC -ListSet MSExchangeIS -ea stop|'select-object'=0 '-ExpandProperty'=0 'CounterSetName
Get-Counter'=0 '-ComputerName'=0 'GHIWPMBX3-DEF'=0 '-ListSet'=0 'MSExchangeIS'=0 '-ea'=0 'stop|select-object'=0 '-ExpandProperty'=0 'CounterSetName
Get-Counter'=0 '-ComputerName'=0 'DEFWPMBX2-ABC'=0 '-ListSet'=0 'MSExchangeIS'=0 '-ea'=0 'stop|select-object'=0 '-ExpandProperty'=0 'CounterSetName
Get-Counter'=0 '-ComputerName'=0 'KLMWPMBX4-DEF'=0 '-ListSet'=0 'MSExchangeIS'=0 '-ea'=0 'stop|select-object'=0 '-ExpandProperty'=0 'CounterSetName
Get-Counter'=0 '-ComputerName'=0 'PQRWVJAR2-DEF'=0 '-ListSet'=0 'MSExchangeIS'=0 '-ea'=0 'stop|select-object'=0 '-ExpandProperty'=0 'CounterSetName
OK:'=0 'MSExchangeIS'=0 'counter'=0 'is'=0 'disabled'=0
Below is the output when executed from the PowerShell console:
Get-Counter -ComputerName ABCWPMBX1-ABC -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName
Get-Counter -ComputerName GHIWPMBX3-DEF -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName
Get-Counter -ComputerName DEFWPMBX2-ABC -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName
Get-Counter -ComputerName KLMWPMBX4-DEF -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName
Get-Counter -ComputerName PQRWVJAR2-DEF -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName
Nsclient.log:
2016-06-02 04:54:19: d:D:\source\nscp\trunk\include\nrpe/server/protocol.hpp:66: Accepting connection from: ::ffff:x.x.x.x
2016-06-02 04:54:19: d:..\..\..\trunk\service\NSClient++.cpp:960: Injecting: alias_check_scripts...
2016-06-02 04:54:19: d:..\..\..\..\trunk\modules\CheckExternalScripts\CheckExternalScripts.cpp:257: Arguments: /c echo scripts\powershell\check_scripts.ps1 ; exit($lastexitcode) | powershell.exe -command -
2016-06-02 04:54:20: d:..\..\..\trunk\service\NSClient++.cpp:985: Result alias_check_scripts: OK
ssax
Dreams In Code
Post by ssax »
Maybe it has something to do with the dashes in the names, try changing it to this:
$commandString = "Get-Counter -ComputerName '$s' -ListSet MSExchangeIS -ea stop|select-object -ExpandProperty CounterSetName"
sc00354007
Please see the below output after doing the changes:
Get-Counter -ComputerName 'ABCWPMBX1-ABC' -ListSet MSExchangeIS -ea stop|'select-object'=0 '-ExpandProperty'=0 'CounterSetName
