Since the update to 2011R1.7 when using the "Network Switch / Router Monitoring Wizard" it appears that it is impossible to click on the button NEXT. This bug appears randomly at different steps of the plugin but each time i use it. Using Internet Explorer 8, there is no problem.
Regards,
Aurélien.
2011R1.7 & Firefox 7.0.1
Configuration:
Nagios XI 2014R2.5
manually upgraded on 64bits CentOS 6
with nothing extra, no gnome, no proxy, no SSL
Add-ons: Hypermap, Minemap, Ping Action, Traceroute Action, Network Replay, Graph Explorer, Latest Alert
Nagios XI 2014R2.5
Re: 2011R1.7 & Firefox 7.0.1
This is a known problem and it's fixed in the our development code. If you really need this to work and you can't wait for the next release, you can try our preview release 2011R1.8rc here. There are still a few problems with that version which is why we haven't pushed it out the door yet, but they are mostly related to clean installs. Upgrades should work fine.
Hope that helps!
Hope that helps!
Thanks for the information, and prefer to wait for the official release, i can work with IE for a while.
And congratulation to the team for your development works, your doing great !!
Configuration:
Nagios XI 2014R2.5
Nagios XI 2014R2.5
