return code of 24 is out of bounds
ouahiba
Post by ouahiba »
I have more than 600 services that went down with this error "return code of 24 is out of bounds".
I can't find the cause.
Could you please help me?
Re: return code of 24 is out of bounds
Can you post your /usr/local/nagios/var/nagios.log file, and also the output of df -i? Additionally, is anything in your /var/log/messages that looks related?
ouahiba
Post by ouahiba »
Here the logs:
notification.log:1464518165;INFORMATION;5972;NOTIFICATION SERVICE MAIL - Receiver : - Message : ***** Notification de la supervision ***** - - Type: PROBLEM - - Service: disk_c - Equipement: QVIPWGTXA01 - Adresse IP: 172.31.1.164 - Catégorie: Serveur Windows - Etat: CRITICAL - Date/Heure: 29-05-2016 12:36:04 - - Consigne: http://**/w/Telephonie_fixe_IP/QVIPWGTXA01#disk_c - Informations détaillées : (Return code of 24 is out of bounds)
notification.log:1464518166;INFORMATION;6015;NOTIFICATION SERVICE MAIL - Receiver : - Message : ***** Notification de la supervision ***** - - Type: PROBLEM - - Service: disk_e_data - Equipement: QVIPWGTXA01 - Adresse IP: 172.31.1.164 - Catégorie: Serveur Windows - Etat: CRITICAL - Date/Heure: 29-05-2016 12:36:05 - - Consigne: http://**/w/Telephonie_fixe_IP/QVIPWGTXA01#disk_e_data - Informations détaillées : (Return code of 24 is out of bounds)
notification.log:1464519882;INFORMATION;22472;NOTIFICATION SERVICE MAIL - Receiver : - Message : ***** Notification de la supervision ***** - - Type: ACKNOWLEDGEMENT - - Service: ram - Equipement: QVIPWMCPI01 - Adresse IP: 172.31.1.81 - Catégorie: Serveur Windows - Etat: CRITICAL - Date/Heure: 29-05-2016 13:04:42 - - Acquitté par: api- - Consigne: http://**/w/IT_SUPERVISION/QVIPWMCPI01#ram - Informations détaillées : (Return code of 24 is out of bounds)
notification.log:1464519883;INFORMATION;22559;NOTIFICATION SERVICE MAIL - Receiver : - Message : ***** Notification de la supervision ***** - - Type: ACKNOWLEDGEMENT - - Service: cpu - Equipement: QVIPWMCPI01 - Adresse IP: 172.31.1.81 - Catégorie: Serveur Windows - Etat: CRITICAL - Date/Heure: 29-05-2016 13:04:43 - - Acquitté par: api - - Consigne: http://**/w/IT_SUPERVISION/QVIPWMCPI01#cpu - Informations détaillées : (Return code of 24 is out of bounds)
notification.log:1464524236;INFORMATION;19598;NOTIFICATION SERVICE MAIL - Receiver : - Message : ***** Notification de la supervision ***** - - Type: ACKNOWLEDGEMENT - - Service: disk_c - Equipement: QVIPWMCPI01 - Adresse IP: 172.31.1.81 - Catégorie: Serveur Windows - Etat: CRITICAL - Date/Heure: 29-05-2016 14:17:15 - - Acquitté par: api - - Consigne: http://**/w/IT_SUPERVISION/QVIPWMCPI01#disk_c - Informations détaillées : (Return code of 24 is out of bounds)
syslog.log
[1464786198] SERVICE EVENT HANDLER: LSDuMy6dZtK9fbYRgjoA2E0xe;rqu8cwMbiDBQXEhY7Cfe4ygxv;OK;SOFT;2;write_syslog_service!NAGIOS-CLIENT!
%CISTATE%~%HOSTALIAS%~%SERVICEDESC%~%OUTPUT%~%INSTRUCTIONS%~{\\"id\\":%CIID%,\\"type\\":%CITYPE%}!1!1
[1464786340] SERVICE EVENT HANDLER: DNMpJWR561AncjmLtSszxeCVh;KJLj0i6DZsbd9QvuMGe3BxRgc;OK;SOFT;4;write_syslog_service!NAGIOS-SERVAIR!
[1464786374] HOST EVENT HANDLER: LB08Qj2675HrXtakGhZSYNvzg;UP;SOFT;2;write_syslog_host!LABEL_VIADEIS!%CISTATE%~%HOSTALIAS%~~%OUTPUT%~%
Have you tried to restart the Nagios server to see if that works for you?
Can you login to the server, run the following and post the output?
df -h
df -i
chage -l nagios
Can you run one of the checks that is failing from a shell and post the output so we can view it?
ouahiba
Post by ouahiba »
here the results:
root@QVIPLVDSI01:~ $ df -h
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
/dev/mapper/VSB--vg-root 7,2G 5,5G 1,3G 82% /
udev 488M 4,0K 488M 1% /dev
tmpfs 100M 264K 100M 1% /run
none 5,0M 0 5,0M 0% /run/lock
none 498M 5,6M 492M 2% /run/shm
/dev/sda1 228M 28M 189M 13% /boot
root@QVIPLVDSI01:~ $ df -i
Sys. de fichiers Inœuds IUtil. ILibre IUti% Monté sur
/dev/mapper/VSB--vg-root 474208 118476 355732 25% /
udev 124909 446 124463 1% /dev
tmpfs 127335 340 126995 1% /run
none 127335 9 127326 1% /run/lock
none 127335 2 127333 1% /run/shm
/dev/sda1 124496 231 124265 1% /boot
root@QVIPLVDSI01:~ $ chage -l nagios
Last password change : janv. 23, 2014
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
Some systems return 24 if there are too many files open... What's your environment? Run the following commands and show the output:
uname -a
cat /etc/*release
lsb_release -a
Can you show us the actual command that you are running from the command line along with the output of it?
Does restarting nagios eliminate the issue?
ouahiba
Post by ouahiba »
here the results:
1.Linux QVIPLVDSI01 3.8.0-29-generic #42~precise1-Ubuntu SMP Wed Aug 14 16:19:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
2.DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04.4 LTS"
NAME="Ubuntu"
VERSION="12.04.4 LTS, Precise Pangolin"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu precise (12.04.4 LTS)"
VERSION_ID="12.04"
3.No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04.4 LTS
Release: 12.04
Codename: precise
Can you show us the actual command ("failing" check) that you are running from the command line along with the output of it?
ouahiba
Post by ouahiba »
this issue appears only twice a year but we would like to know why.
do you have any ideas?
There isn't enough information to give a valid reason for this. We would need to see the nagios.log file from that day to see if there are any errors / details that could help debug this issue.
