Add service
simpleacc
Add service
Post by simpleacc »
Hello guys,
I am newbie with nagios and I need some help... I have installed this fantastic software into my Debian server. Now I am configuring it and need support with one topic...
I want to add a simple check (temperature). I can check system's temperature from "/sys/class/thermal/thermal_zone0/temp". I have tried add this into commands.cfg. I am 115% sure that I was wrong :(
command_name temp
command_line cat /sys/class/thermal/thermal_zone0/temp
Someone can explain me how to create this service? I have tried find a 'google' solution but... nothing.
Sorry for the inconvenience.
Thanks in advance.
Re: Add service
Just to clarify - you posted this in the Nagios XI section, are you using XI or Nagios Core?
For the record, Nagios XI will not run stable on debian currently.
simpleacc
Re: Add service
Post by simpleacc »
I am using Nagios Core. Maybe was a wrong section... Sorry
Moderator's Note: We moved the post to the Nagios Core Support forum.
Re: Add service
I would create a bash script, in your /usr/local/nagios/libexec/ directory, and then in it put your bash commands like so -
#!/bin/bash
Make sure it's executable, and that the permissions match the rest of your plugins (depending on how you installed Core). Then, create your command definition like this. (you could always do further regex matching to get certain variables, and add thresholds) -
command_name temp
command_line $USER1$/yourscript.sh
Now, assign the check_command temp to a service.
