Hi Guys
When I access XI using 80 port, everything working fine, but when I change the listening port 80 to others, I got some problem.
1.Network Status Map got nothing
2.Monitoring Process got some error
Could you help me how to change the XI web listening port ?
How to change Nagios XI listening port ???
eric.lin826
- Box293
- Too Basu
Re: How to change Nagios XI listening port ???
How are you changing the listening port?eric.lin826 wrote: but when I change the listening port 80 to others, I got some problem.
Can you please post any config files you are modifying.
eric.lin826
Hi
I change /etc/httpd/conf/httpd.conf file.
ex. change line 136's "Listen 80" to "Listen 8080"
I haven't tested this, but you could try to change
to
in /usr/local/nagiosxi/html/config.inc.php, and then restart apache.
Let me know if this works.
$cfg['port_number'] = false;Code: Select all
$cfg['port_number'] = 8080;Let me know if this works.
Former Nagios Employee.
me.
me.
eric.lin826
Hi hsmith
It works. Thanks for your help!
