Check NIC Status.
Uday Kumar
Check NIC Status.
Post by Uday Kumar »
Hi Team,
we are facing below error while trying to check NIC status by using check_nics.pl
Description : CRITICAL - Benchmark key Link detected does not exist in the ethtool report for eth0, change the script /usr/local/nagios/libexec/check_nics.pl accordingly.
For few days its working fine but suddenly it started throwing the above error, Can you please help us to sort out the error.
Re: Check NIC Status.
Post by Box293 »
Can you please show us where you downloaded this plugin from, or upload it here.
Can you show us an example of executing the plugin at the command line along with the output it produces.
Uday Kumar
Please find the below output from terminal and also the attached check.(Same check is used for both below servers)
Using below service for calling
use dba-service
host_name 1234
service_description Check NIC status
check_command check_nrpe!racnsw1-rh1!check_nics
From a working server:
[root@123 libexec]# ./check_nics.pl
OK - ALL NICs are working fine.
NIC eth0:1000Mb/s,Full,Auto-negotiation is on.
From a non working server:
[root@12354 libexec]# ./check_nics.pl
CRITICAL - Benchmark key Link detected does not exist in the ethtool report for eth0, change the script ./check_nics.pl accordingly.
Benchmark key Link detected does not exist in the ethtool report for eth1, change the script ./check_nics.pl accordingly.
Benchmark key Link detected does not exist in the ethtool report for eth3, change the script ./check_nics.pl accordingly.
check_nics.pl
(4.03 KiB) Downloaded 316 times
Can you run the following commands on the "non working" server, and show the output?
which ethtool
ip addr
grep ethtool /etc/sudoers
Uday Kumar
Please find the below out puts from non working server.
[root@racnsw3-rh1 ~]# which ethtool
/sbin/ethtool
[root@racnsw3-rh1 ~]# ip addr
1: lo: <LOOPBACK,UP> mtu 16436 qdisc noqueue
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 brd 127.255.255.255 scope host lo
    inet6 ::1/128 scope host
       valid_lft forever preferred_lft forever
2: bond0: <BROADCAST,MULTICAST,MASTER,UP> mtu 1500 qdisc noqueue
    link/ether 00:1a:4b:07:06:45 brd ff:ff:ff:ff:ff:ff
    inet 192.168.76.41/29 brd 192.168.76.47 scope global bond0
    inet6 fe80::200:ff:fe00:0/64 scope link
3: eth0: <BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast qlen 1000
    link/ether 00:1a:4b:07:06:44 brd ff:ff:ff:ff:ff:ff
    inet 172.16.130.235/24 brd 172.16.130.255 scope global eth0
    inet 172.16.130.237/24 brd 172.16.130.255 scope global secondary eth0:1
    inet6 fe80::21a:4bff:fe07:644/64 scope link
4: eth1: <BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000
5: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
    link/ether 00:1a:4b:08:64:e4 brd ff:ff:ff:ff:ff:ff
6: eth3: <BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000
7: sit0: <NOARP> mtu 1480 qdisc noop
    link/sit 0.0.0.0 brd 0.0.0.0
[root@racnsw3-rh1 ~]# grep ethtool /etc/sudoers
#Wallace added ethtool for Nagios account
nagios  ALL=(ALL) NOPASSWD:/sbin/ethtool
Can you login to the remote server, run the following commands and post the output?
chage -l nagios
ethtool eth0
su nagios
ethtool eth0
Uday Kumar
Hi ,
[root@racnsw3-rh1 ~]# chage -l nagios
chage: unknown user: nagios
[root@racnsw3-rh1 ~]# ethtool eth0
Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: umbg
Wake-on: g
Current message level: 0x00000007 (7)
Link detected: yes
[root@racnsw3-rh1 ~]# su nagios
su: user nagios does not exist
It looks like the nagios user didn't get created on that server.
Can you login to that server as root, run the following commands to create the nagios user and groups?
useradd nagios
groupadd nagios
groupadd nagcmd
usermod -a -G nagcmd nagios
usermod -a -G nagios nagios
After that is done, run the following to see if the nagios account can run the ethtool command and the check itself.
su nagios
ethtool eth0
./check_nics.pl
If the above passes, check to see if Nagios Core is working now and let us know if it does.
Uday Kumar
Hi Team,
Thanks a lot, Much appreciated.
Its working fine now.
