Hi
When i monitor the core switch and it's interface's snmp oid index great then some value, the rrd file couldn't create automatically.
Is anyone can help?
RRD does not exist
eric.lin826
RRD does not exist
Re: RRD does not exist
When did you create this service? This is normal behavior for about 10 minutes, until the rrd is created.
eric.lin826
Hi
The service was created about 20 minutes, when I check this service after 16 hours, it still on the same situation.
- Box293
- Too Basu
Can you see if this KB article resolves your issue:
https://support.nagios.com/kb/article.php?id=511
If it doesn't, do you see any errors when you run the following command?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
eric.lin826
Hi Box293
Thanks for your information.
I resolve this issue by the KB article.
https://support.nagios.com/kb/article.php?id=512
