Migration from EZNag nagios 3.3.1 to Nagios core 4.0.1
isub
Post by isub »
copied old nagios configuration files from old nagios server 3.3.1 to new nagios core 4.0.1 and restarted nagios got some errors.
Running configuration check...
Nagios Core 4.0.4
Last Modified: 03-14-2014
License: GPL
Reading configuration data...
Read main config file okay...
Error: Invalid notification option 'options' in service definition.
Error: Could not add object property in file '/usr/local/nagios/etc/objects/svc_nrpe.cfg' on line 69.
cat objects/svc_nrpe
svc_nrpe.cfg svc_nrpe-Groups.cfg svc_nrpe-Storage.cfg
isub
Re: Migration from EZNag nagios 3.3.1 to Nagios core 4.0.1
Please post the entire file /usr/local/nagios/etc/objects/svc_nrpe.cfg for us to look at.
isub
Post by isub »
Attached /usr/local/etc/nagios/objects/nrpe.cfg
nrpe.cfg.txt
svc_nrpe.cfg
(11.25 KiB) Downloaded 185 times
isub wrote:Attached /usr/local/etc/nagios/objects/nrpe.cfg
The file that's erroring out is actually /usr/local/nagios/etc/objects/svc_nrpe.cfg - can you attach this one?
isub
Post by isub »
Sorry , This is the config file got it from /usr/local/nagios/etc/objects/svc_nrpe.cfg location from my old EZnag nagios 3.3.1 server. Thanks.
You will need to edit that file and add the missing settings for all of the notification_options that are blank or delete the option if you do not need it and see if that resolves the issue.
isub
Post by isub »
Thank you. I will check it.
Let us know if you have any other questions.
isub
Post by isub »
edited /usr/local/nagios/etc/objects/svc_nrpe.cfg and fixed notification errors, but new errors on /usr/local/nagios/etc/objects/timeperiods.cfg
[root@xxxxx objects]# service nagios restart
Nagios Core 4.0.4
License: GPL
Warning: Duplicate definition found for timeperiod '24x7' (config file '/usr/local/nagios/etc/objects/timeperiods.cfg', starting on line 27)
Error: Could not add object property in file '/usr/local/nagios/etc/objects/timeperiods.cfg' on line 28.
Everytime you get an error when restarting the Nagios daemon, you will have to edit that file and correct the error.
Take a look at '/usr/local/nagios/etc/objects/timeperiods.cfg' on line 28.
