Hi all,
Was wondering if anyone out there has successfully monitored, or is monitoring a Jesse 8.5 O/S on ARM hardware?
When trying to install the native client, I get an incompatibility error. Also, SNMP doesn't work.
Any suggestions would be very helpful.
Paul.
Monitoring Jessie 8.5 on ARM with NagiosXI
- Box293
- Too Basu
Re: Monitoring Jessie 8.5 on ARM with NagiosXI
For these scenarios I like check_by_ssh as it removes agents.
It does mean that you need to use plugins that are scripts (if you cannot get them compiled).
https://support.nagios.com/kb/article.php?id=247
As for SNMP not working, what exactly isn't working?
Hi all,
I've been able to monitor my Raspbian Jessie with NRPE. You need to compile manually though. I'll see about making a how-to.
Grtz
Grtz
Nagios XI 5.8.1
https://outsideit.net
Paul,
Could you give this procedure a try:
https://outsideit.net/monitor-raspberry/
It worked for me every time. Let us know if you encounter any issues.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
You're fast! Thanks Willem!WillemDH wrote:Paul,
Grtz
Willem
@PaulV - let us know if you have any further questions.I'll see about making a how-to. Give me a few days.
