Hypermap uses only left half of 23" monitor screen
cskang
Post by cskang »
I am using 23" monitor and my network has around 35 hosts.
I am trying to fit all hosts in the monitor screen to have a network wide view using Hypermap.
However, it seems like that Hypermap is only using about a half of the monitor screen.
"About This Map" text block is displayed in the center of the screen and I don't know how to move it to the right corner.
Is there any way to utilize the entire monitor screen with Hypermap?
Re: Hypermap uses only left half of 23" monitor screen
I was able to confirm this behavior - it is possible that this is a bug. You can post it on our bug tracker:
http://tracker.nagios.com/login_page.php
penthese
Post by penthese »
I was wondering if this bug is resolved.
We're encountering the same problem
Gr.
Yes, it's resolved. Here's the developer's notes:
A 1.1 version of this component has just been published that uses a dynamic CSS width for the map. A static height of the original 600px still had to be maintained in order for the map to display properly, but the width will now adjust for larger screens as needed.
You can view the bug report here:
http://tracker.nagios.com/view.php?id=196
Note: Make sure you are using version 1.1 of the Hypermap component.
Sturm
Post by Sturm »
I'm having the same problem.
I've installed the 1.1 version but it's still the same. I think the component is not using the configured CSS. Because if i delete the CSS map in the hypermap.zip and reinstall the component in nagiosxi it still displays the hypermap. But the deshlet.inc.php does point to css/base.css and css/hypermap.css.
Any ideas?
Greetz.
Post by slansing »
What version of nagios xi are you running?
Sturm
Post by Sturm »
I'm using Nagios XI 2012R2.2.
Gr.
removing the CSS won't make the hypermap disappear.. it will still display.
Would it be possible to post a screen shot?
What browser and browser version are you using?
Sturm
Post by Sturm »
screen shot:
I'm currently working with:
Firefox 21.0
But i've also tested it with:
Chrome 27.0.1453.116 m
IE 10.0.9200.16618
My NagiosXI setup:
Nagios XI 2012R2.2
Nagios® Core™ Version 3.5.0
Hypermap V1.1
129 Hosts
abrist
Red Shirt
Post by abrist »
That screenshot is from a dashboard/view. Does it have the same issue when you browse to the component directly from the Home --> Maps --> Hypermap page in XI?
