An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Error: Command name of command line is NULL
Error: Could not register command (config file '/usr/local/nagios/etc/commands.cfg', starting on line 276)
http://nagiosxi/admin/coreconfigsnapshots.php
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Configurations failed to write to file.
Re: Configurations failed to write to file.
Can you check line 276 of that file and post what is there?Error: Could not register command (config file '/usr/local/nagios/etc/commands.cfg', starting on line 276)
Former Nagios Employee.
me.
me.
almanasra2005
command_name check_xi_service_ftp
command_line $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_hpjd
command_line $USER1$/check_hpjd -H $HOSTADDRESS$ -C $ARG1$
command_name check_xi_service_http
command_line $USER1$/check_http -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_http_cert
command_line $USER1$/check_http -H $HOSTADDRESS$ -C $ARG1$
command_name check_xi_service_http_content
command_line $USER1$/check_http -H $HOSTADDRESS$ --onredirect=follow -s "$ARG1$"
command_name check_xi_service_ifoperstatus
command_line $USER1$/check_ifoperstatus -H $HOSTADDRESS$ -C $ARG1$ -k $ARG2$ $ARG3$
command_name check_xi_service_ifoperstatusnag
command_line $USER1$/check_ifoperstatnag $ARG1$ $ARG2$ $HOSTADDRESS$
command_name check_xi_service_imap
command_line $USER1$/check_imap -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_ldap
command_line $USER1$/check_ldap -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_mrtgtraf
command_line $USER1$/check_rrdtraf -f /var/lib/mrtg/$ARG1$ -w $ARG2$ -c $ARG3$ -l $ARG4$
command_name check_xi_service_nagioslogserver
command_line $USER1$/check_nagioslogserver.php $ARG1$
command_name check_xi_service_none
command_line $USER1$/check_dummy 0 "Nothing to monitor"
command_name check_xi_service_nsclient
command_line $USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$ $ARG4$
command_name check_xi_service_ping
command_line $USER1$/check_icmp -H $HOSTADDRESS$ -w $ARG1$,$ARG2$ -c $ARG3$,$ARG4$ -p 5
command_name check_xi_service_pop
command_line $USER1$/check_pop -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_smtp
command_line $USER1$/check_smtp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp
command_line $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_linux_load
command_line $USER1$/check_snmp_load_wizard.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_linux_process
command_line $USER1$/check_snmp_process_wizard.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_linux_storage
command_line $USER1$/check_snmp_storage_wizard.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_watchguard
command_line $USER1$/check_snmp_generic.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_load
command_line $USER1$/check_snmp_load.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_process
command_line $USER1$/check_snmp_process.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_service
command_line $USER1$/check_snmp_win.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_storage
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_ssh
command_line $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
command_name check_xi_service_status
command_line sudo /usr/local/nagiosxi/scripts/manage_services.sh status $ARG1$
command_name check_xi_service_tcp
command_line $USER1$/check_tcp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_udp
command_line $USER1$/check_udp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_webinject
command_line $USER1$/check_webinject.sh $ARG1$
command_name check_xi_service_wmiplus
command_line $USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$ -m $ARG3$ $ARG4$
command_name check_xi_service_wmiplus_authfile
command_line $USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -A $ARG1$ -m $ARG2$ $ARG3$
command_name check_xi_sla
command_line $USER1$/check_xisla.php $ARG1$
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
command_name process-host-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.host
command_name process-host-perfdata-file-pnp-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/perfdata/host-perfdata.$TIMET$
command_name process-host-perfdata-pnp-normal
command_line /usr/bin/perl /usr/local/nagios/libexec/process_perfdata.pl -d HOSTPERFDATA
command_name process-service-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.service
command_name process-service-perfdata-file-pnp-bulk
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/perfdata/service-perfdata.$TIMET$
command_name process-service-perfdata-pnp-normal
command_name vmware_cluster_cpu_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Cluster_CPU_Usage --cluster \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_cluster_drs
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Cluster_DRS_Status --cluster \"$ARG3$\" --drs_state \"$ARG4$\" --drs_automation_level \"$ARG5$\" --drs_dpm_level \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_cluster_ha
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Cluster_HA_Status --cluster \"$ARG3$\" --ha_state \"$ARG4$\" --ha_host_monitoring \"$ARG5$\" --ha_admission_control \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_cluster_memory_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Cluster_Memory_Usage --cluster \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_datastore_performance_esx
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Datastore_Performance --name \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_datastore_performance_vcenter
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Datastore_Performance --host \"$ARG3$\" --name \"$ARG4$\" --reporting_si \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_datastore_performance_vcenter_wac
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Datastore_Performance --host \"$ARG3$\" --name \"$ARG4$\" --reporting_si \"$ARG5$\" --warning \"$ARG6$\" --critical \"$ARG7$\" \"$ARG8$\""
command_name vmware_datastore_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Datastore_Usage --name \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_cpu_info
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_CPU_Info --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_cpu_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_CPU_Usage --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_disk_performance
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_Disk_Performance --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_disk_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_Disk_Usage --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_memory_info
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_Memory_Info --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_memory_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_Memory_Usage --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_nic_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_NIC_Usage --guest \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_guest_snapshot
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Guest_Snapshot \"$ARG3$\" \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_hba_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Storage_Adapter_Performance --name \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_pnic_status
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Status --nic_state \"$ARG3$\" --nic_duplex \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_pnic_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Usage --reporting_si \"$ARG3$\" \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_pnic_usage_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Usage --reporting_si \"$ARG3$\" --name \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_switch_status
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --nic_state \"$ARG3$\" --nic_duplex \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_switch_status_mtu
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --nic_state \"$ARG3$\" --nic_duplex \"$ARG4$\" --mtu \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_switch_status_mtu_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --name \"$ARG3$\" --nic_state \"$ARG4$\" --nic_duplex \"$ARG5$\" --mtu \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_esx_switch_status_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --name \"$ARG3$\" --nic_state \"$ARG4$\" --nic_duplex \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check \"$ARG3$\" --host \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_cpu_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_CPU_Usage --host \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_hba_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Storage_Adapter_Performance --host \"$ARG3$\" --name \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_hba_usage_wac
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Storage_Adapter_Performance --host \"$ARG3$\" --name \"$ARG4$\" --reporting_si \"$ARG5$\" --warning \"$ARG6$\" --critical \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_memory_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Memory_Usage --host \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_pnic_status
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Status --host \"$ARG3$\" --nic_state \"$ARG4$\" --nic_duplex \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_pnic_status_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Status --host \"$ARG3$\" --name \"$ARG4$\" --nic_state \"$ARG5$\" --nic_duplex \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_pnic_usage
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Usage --host \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_pnic_usage_wac
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_pNIC_Usage --host \"$ARG3$\" --reporting_si \"$ARG4$\" --warning \"$ARG5$\" --critical \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_switch_status
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --host \"$ARG3$\" --nic_state \"$ARG4$\" --nic_duplex \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_switch_status_mtu_1500
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --host \"$ARG3$\" --nic_state \"$ARG4$\" --nic_duplex \"$ARG5$\" --mtu 1500 \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_switch_status_mtu_1500_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --host \"$ARG3$\" --name \"$ARG4$\" --nic_state \"$ARG5$\" --nic_duplex \"$ARG6$\" --mtu 1500 \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_switch_status_mtu_9000
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --host \"$ARG3$\" --name \"$ARG4$\" --nic_state \"$ARG5$\" --nic_duplex \"$ARG6$\" --mtu 9000 \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_switch_status_mtu_9000_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --host \"$ARG3$\" --nic_state \"$ARG4$\" --nic_duplex \"$ARG5$\" --mtu 9000 \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_host_vcenter_switch_status_named
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check Host_Switch_Status --host \"$ARG3$\" --name \"$ARG4$\" --nic_state \"$ARG5$\" --nic_duplex \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_universal
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check \"$ARG3$\" \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name vmware_universal_reporting_si
command_line $USER1$/check_by_ssh -E 1 -t 90 -l vi-admin -H $ARG1$ -C "~/box293_check_vmware.pl --timeout 90 --server $ARG2$ --check \"$ARG3$\" --reporting_si \"$ARG4$\" \"$ARG5$\" \"$ARG6$\" \"$ARG7$\" \"$ARG8$\""
command_name xi_host_event_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=host --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --lasthoststate=$LASTHOSTSTATE$ --lasthoststateid=$LASTHOSTSTATEID$ --hoststatetype=$HOSTSTATETYPE$ --currentattempt=$HOSTATTEMPT$ --maxattempts=$MAXHOSTATTEMPTS$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --hostoutput="$HOSTOUTPUT$" --longhostoutput="$LONGHOSTOUTPUT$" --hostdowntime=$HOSTDOWNTIME$
command_name xi_host_notification_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_notification.php --notification-type=host --contact="$CONTACTNAME$" --contactemail="$CONTACTEMAIL$" --type=$NOTIFICATIONTYPE$ --escalated="$NOTIFICATIONISESCALATED$" --author="$NOTIFICATIONAUTHOR$" --comments="$NOTIFICATIONCOMMENT$" --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hostalias="$HOSTALIAS$" --hostdisplayname="$HOSTDISPLAYNAME$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --lasthoststate=$LASTHOSTSTATE$ --lasthoststateid=$LASTHOSTSTATEID$ --hoststatetype=$HOSTSTATETYPE$ --currentattempt=$HOSTATTEMPT$ --maxattempts=$MAXHOSTATTEMPTS$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --hostoutput="$HOSTOUTPUT$" --longhostoutput="$LONGHOSTOUTPUT$" --datetime="$LONGDATETIME$"
command_name xi_service_event_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=service --host="$HOSTNAME$" --service="$SERVICEDESC$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" --servicedowntime=$SERVICEDOWNTIME$
command_name xi_service_notification_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_notification.php --notification-type=service --contact="$CONTACTNAME$" --contactemail="$CONTACTEMAIL$" --type=$NOTIFICATIONTYPE$ --escalated="$NOTIFICATIONISESCALATED$" --author="$NOTIFICATIONAUTHOR$" --comments="$NOTIFICATIONCOMMENT$" --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hostalias="$HOSTALIAS$" --hostdisplayname="$HOSTDISPLAYNAME$" --service="$SERVICEDESC$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" --datetime="$LONGDATETIME$"
# Check command configuration file
# END OF FILE
Reason: please wrap long/technical outputs in [code] tags
almanasra2005
I still have this error
- Box293
- Too Basu
Do this:
Go into CCM
Tools > Write Config Files
Click the Write Button
It will show an output of all the files it creates
Click the Verify button
The output should end with the error you are getting.
Now upload the file /usr/local/nagios/etc/commands.cfg
The snipped you uploaded before was the "good" file that it rolled back to. The steps I showed you above has the file in the error state and we'll be able to better see what is going on.
I suspect though that the error "Command name of command line is NULL" is the actual cause of your problem. Go to:
CCM
Commands > Commands
Do you have any commands that have an empty "Command Name" field?
If you do, you need to resolve this.
If you don't, perhaps you have a database error.
Run this command
Send us this file:
/tmp/mysqld_log.txt
Go into CCM
CCM
Commands > Commands
Run this command
tail /var/log/mysqld.log -n 100 > /tmp/mysqld_log.txt/tmp/mysqld_log.txt
