nrpe agent installation fails on SLES11 SP3
kaka81
Post by kaka81 »
Hi @all,
I tried to install nrpe agent on a Linux SLES11 SP3 OS. Never had any problems with other installations but somethings works wrong here.
Please find attached install.log file.
I don't see any issues there.
Thank you for your support.
Cheers, Christoph
Re: nrpe agent installation fails on SLES11 SP3
Is that your full install.log or did it get truncated? The last part I'm seeing is -
Installing SUSE SDK ...
Preparing...                ##################################################
	package sle-sdk-release-SDK-11.3-1.69.x86_64 is already installed
	package sle-sdk-release-11.3-1.69.x86_64 is already installed
What issues are you encountering?
kaka81
Post by kaka81 »
Yes, that's full install log, nothing else to see
hsmith
Agent Smith
Post by hsmith »
Are you just trying to run ./fullinstall as root?
Former Nagios Employee.
me.
kaka81
Post by kaka81 »
yes, always logged in with root user and I tried "sudo ./fullinstall". I just tried it again, following error at the end (after "package ... is already installed" as you wrote above):
RESULT=4
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
hsmith
Agent Smith
Post by hsmith »
Can you try to run the fullinstall script with bash -x fullinstall? Post the full output here.
me.
kaka81
Post by kaka81 »
Here's the output:
+ ./init.sh
+ . ./xi-sys.cfg
++ apachegroup=apache
++ apacheuser=apache
++ chownbin=/bin/chown
++ groupaddbin=/usr/sbin/groupadd
++ groupdelbin=/usr/sbin/groupdel
++ htpasswdbin=/usr/bin/htpasswd
++ httpdconfdir=/etc/httpd/conf.d
++ httpd=httpd
++ mkdirbin=/bin/mkdir
++ mrtgcfg=/etc/mrtg/mrtg.cfg
++ mysqld=mysqld
++ mysqlpass=nagiosxi
++ pgsqlrootpass=postgres
++ pgsqlpass=nagiosxi
++ nagioscmdgroup=nagcmd
++ nagiosgroup=nagios
++ nagiosuser=nagios
++ nagioswebpwd=nagiosadmin
++ nagioswebuser=nagiosadmin
++ phpconfd=/etc/php.d
++ php_extension_dir=/usr/lib/php/modules
++ phpini=/etc/php.ini
++ proddir=/usr/local/nagiosxi
++ useraddbin=/usr/sbin/useradd
++ usermodbin=/usr/sbin/usermod
++ userdelbin=/usr/sbin/userdel
++ xiver=2011r2.3
++ distro='SUSE LINUX'
++ version=11.3
++ ver=11
++ architecture=x86_64
++ dist=suse
++ arch=x86_64
+ log=install.log
+ export INTERACTIVE=True
+ INTERACTIVE=True
++ id -u
+ '[' 0 -ne 0 ']'
+ caninstall=no
+ '[' 'SUSE LINUX' == CentOS ']'
+ '[' 'SUSE LINUX' == RedHatEnterpriseServer ']'
+ '[' 'SUSE LINUX' == openSUSE ']'
+ '[' 'SUSE LINUX' == 'SUSE LINUX' ']'
+ caninstall=yes
+ case "$dist" in
+ '[' yes == no ']'
+ path_is_ok
+ awk 'BEGIN{RS=":"} {p[$0]++} END{if (p["/sbin"] && p["/usr/sbin"]) exit(0); exit(1)}'
+ echo /opt/oracle/product/11.2/db_1/bin:/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
+ '[' -n '' ']'
+ '[' True = True ']'
+ cat
Nagios Linux Agent Installer
This script will install the Nagios Linux Agent by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a clean installed system:
RedHat Enterprise, CentOS, Fedora, or Oracle
OpenSUSE or SUSE Enterprise
Ubuntu or Debian
Do NOT use this on a system running any other distro or that
does not allow additional package installation.
+ read -p 'Do you want to continue? [Y/n] ' res
Do you want to continue? [Y/n] Y
+ case "$res" in
+ echo 'Proceeding with installation...'
+ cat
++ date
+ run_sub ./0-repos noupdate
+ echo 'Running '\''./0-repos'\''...'
Running './0-repos'...
+ FAILFILE=.fail-12519
+ rm -f .fail-12519
+ eval ./0-repos noupdate
+ tee -a install.log
++ ./0-repos noupdate
Configuring Repos...
Downloading SUSE SDK ...
--2016-06-13 22:13:54-- https://nu.novell.com/repo/$RCE/SLE11-S ... x86_64.rpm
Auflösen des Hostnamen »nu.novell.com«.... 68.232.34.212
Verbindungsaufbau zu nu.novell.com|68.232.34.212|:443... verbunden.
HTTP Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 3447 (3,4K) [application/octet-stream]
In »sle-sdk-release-11.3-1.69.x86_64.rpm.2« speichern.
0K ... 100% 5,04M=0,001s
2016-06-13 22:13:54 (5,04 MB/s) - »sle-sdk-release-11.3-1.69.x86_64.rpm.2« gespeichert [3447/3447]
Länge: 2814 (2,7K) [application/octet-stream]
In »sle-sdk-release-SDK-11.3-1.69.x86_64.rpm.2« speichern.
0K .. 100% 6,78M=0s
2016-06-13 22:13:55 (6,78 MB/s) - »sle-sdk-release-SDK-11.3-1.69.x86_64.rpm.2« gespeichert [2814/2814]
+ echo 6
++ cat .fail-12519
+ echo RESULT=6
RESULT=6
+ '[' -f .fail-12519 ']'
+ cat
INSTALLATION ERROR!
+ exit 1
Post by Box293 »
What is the output of these commands:
suse_register
zypper pd
kaka81
Post by kaka81 »
zypper pd:
[09:26] [root@at466tasi1-TestInstallation ~]$ zypper pd
Daten des Repositorys laden ...
Installierte Pakete lesen ...
S | Repository | Interner Name | Name | Version | Arch | Ist Basis
i | @System | SUSE_SLES | SUSE Linux Enterprise Server 11 SP3 | 11.3-1.138 | x86_64 | Ja
i | @System | sle-sdk | SUSE Linux Enterprise Software Development Kit 11 SP3 | 11.3-1.69 | x86_64 | Nein
suse_register:
with which options?
I think he is trying to determine is your server is registered, is it?
Can you reinstall the sle-sdk-release-11.3-1.69 package and see if the NRPE installation continues on?
