Dear Support,
We scan our Nagios server has some medium vulnerability issue needed to fix,please refer to attach report.Thanks.
Please check in "Medium" risk level.
Kelvin
Nagios Server vulunerability issues
cyberportnoc
Re: Nagios Server vulunerability issues
I see you also opened a ticket for this, so I have addressed the issue there. In the future please only open either a ticket or a forum post, so we are not doubling our answers.
For reference, the issues mentioned are related to the SSL self-signed certificate in use, and the Apache settings allowing weak encryption. These will need to be looked at by your security, network, or sysadmin team.
