check_http -k is not able to handle spaces
vellala2000
Post by vellala2000 »
check_http -k "appid: national retail" -H national.retail.com is failing to read the full header when space is involved. looks like bug with check_http
by the way i am using centos and its the latest version of check_http plugin 2.1.2. i am getting 400 errors as check_http not including entire header.
Re: check_http -k is not able to handle spaces
Can you show us the full input / output you're using and seeing so that we can try to replicate this?
