Nagios - Reports
raamardhani7
Nagios - Reports
Post by raamardhani7 »
Hi Team,
Is there any option that we can generate reports using nagios for the below requirement.
capacity planing reports in histogram format.
Example: report should tell what is the current usage of disks/cpu/memory on weekly basis and it should give me information on which are all the servers using more than 80% and which are being less used. so that capacity planning needs to be done.
Could you please help us here. thanks.
bwallace
Re: Nagios - Reports
Post by bwallace »
To start with, configure each service to be in their own group. For example you 'll have to configure all Memory services to be in a "Memory" service group, then you can restrict the Availability (or Capacity Planning) Report to just that service group. Do the same for disk_space, then CPU, etc...
As for the histogram format, that is not available though.
raamardhani7
Thanks a lot team for the update. we can close this thread, if any updates required, i ll open a new request.
bwallace
Post by bwallace »
You're welcome! I'll close this thread now.
