Check_nrpe socket time out after 10 seconds for windows host
rohithroki
Post by rohithroki »
Dear Team,
I am getting the below error in one of the windows server for 2 services configured with nrpe.
Critical:Check_nrpe socket time out after 10 seconds for windows host.
please find the nmap results from nagios server :
nmap -p 5666,12489 ip of windows host
5666/tcp open nrpe
12489/tcp open unknown
I am getting the below error from nagios server even even if i change the time to 120
Attaching the NSC file of the windows server
/usr/local.nagios/libex/check_nrpe -H ip of windows host -t 120
Check_nrpe socket time out after 120 seconds.
NSC.ini
NSC file
(13 KiB) Downloaded 823 times
hsmith
Agent Smith
Re: Check_nrpe socket time out after 10 seconds for windows
Post by hsmith »
Can you try to telnet to port 5666?
Former Nagios Employee.
me.
rohithroki
yes telnet working fine from nagios server
hsmith
Agent Smith
Post by hsmith »
What version of NSClient are you running?
me.
rohithroki
NSClient++ - 0.3.9.328
hsmith
Agent Smith
Post by hsmith »
10.211.26.68 is your Nagios server?
me.
rohithroki
yes that correct
rohithroki wrote:Dear Team,
5666/tcp open nrpe
Is it just 2 specific checks that aren't working? Are the rest working fine through NRPE? This could be an issue with specific plugins. Can you show us the full check_command that these services are running, as well as the plugins they're utilizing?
rohithroki
no only the plugins configured with nrpe is not working
even when i give the command
/usr/local/nagios/libex/check_nrpe -H ip of host throws me socket timed out. where its succesful for some other hosts
Post by Box293 »
rkennedy wrote: Can you show us the full check_command that these services are running, as well as the plugins they're utilizing?
