Template create a new service check that is the same
jkinning
Post by jkinning »
I am using a service template to monitor all basic server "stuff", CPU, RAM, Disk Space, RDP, etc. The notifications for the service template is Server Management group. I have another Business Unit that would like to receive and view disk space on their servers. I am trying to figure out the best method to provide this to them. Would that be to create a new service check for disk space and make them the contacts? Does that have any negative impact on the servers or Nagios to monitor the same check twice on the server? Is there a different method I can or should use to provide this separate disk check?
eloyd
Cool Title Here
Re: Template create a new service check that is the same
Post by eloyd »
Make a new service template that "use"s the original template, and then change/add/remove the things that do not apply in the new template. Details are at https://assets.nagios.com/downloads/nag ... tance.html
bwallace
Post by bwallace »
That is correct eloyd -- OP, let us know how that works out, thanks.
