Nagios 4 and ndoutils 2.0
tunechi
Post by tunechi »
Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =7&t=32028
In the future, please create a new thread and link to the old one instead of adding on.
I have installed Nagios Core 4.1.1. to monitoring a xen server.
I have the nagios plugins 2.1.1. and the nrpe 2.15, everything works fine but now I want to install the NDOutils 2.0.0 to store all the information of the server that I'm monitoring in a database.
I follow some tutorial, old NDOutils versions, and everything "fine" but the tables of the database that I created is empty and there aren't no information.
What can I do?
Re: Nagios 4 and ndoutils 2.0
Did you follow a specific guide?
Perhaps our KB article will help you out - https://support.nagios.com/kb/article.php?id=406 - might be worth taking a look through this to see if something was missed.
tunechi
Post by tunechi »
Ok, I'm gonna try to do it again.
I've used Ubuntu 14.04 like operating system... and some parts I can't follow the guide (https://support.nagios.com/kb/article.php?id=406).
Exist any other guide about how to install NDOUtils on a Ubuntu 14.04 server running Nagios Core 4.x.
The GitHub page for NDO should be helpful and fairly OS-agnostic:
https://github.com/NagiosEnterprises/ndoutils
Post by Box293 »
Please keep me posted on your Ubuntu progress with this, I have no problem creating an article for installing it on Ubuntu.
