This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
bzsparks
Posts: 6 Joined: Tue Jun 14, 2016 5:07 pm
Post
by bzsparks » Wed Jun 15, 2016 4:26 pm
We're evaluating Nagios to replace our Solarwinds install. I have a fresh install of XI 5.2.9, when I go to the configuration wizard to add a router it will hang on "waiting for configuration verification". On the first screen I configure the snmp community string, the router is detected and I'm presented with all the interfaces for monitoring. Next I accept the monitoring defaults and click finish, this is where the system hangs.
I've done preliminary troubleshooting and edited the php.ini files with the values below.
max_execution_time = 120
max_input_time = 120
memory_limit = 256M
Any help is appreciated.
bzsparks on Wed Jun 15, 2016 5:18 pm, edited 1 time in total.
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Wed Jun 15, 2016 4:47 pm
Please post your /etc/hosts file, and a screenshot of your Admin -> System Settings page.
Additionally, what URL are you using to access the page?
bzsparks
Post
by bzsparks » Thu Jun 16, 2016 10:20 am
Thank you for your help.
The hosts file looks like it has some weird line endings, is this normal?
[root@ndevva01 etc]# cat /etc/hosts
127.0.0.1 localhost.localdomain localhost.localdomain localhost4 localhost4.localdomain4 ndevva01
::1 localhost.localdomain localhost.localdomain localhost6 localhost6.localdomain6 ndevva01
System Settings
we're using the IP at the moment
https://X.X.X.X/nagiosxi/admin/
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Thu Jun 16, 2016 2:25 pm
How many interfaces do you see on Step 2 of the "Network Switch / Router" monitoring wizard? Can you run other monitoring wizards successfully? Can you apply configuration?
Run the following commands, and show the output in code wraps:
uname -a
cat /etc/*release
tail -100 /var/log/httpd/error_log
PS
I will be moving this thread to the Nagios XI support forum as it is in a wrong place.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
bzsparks
Post
by bzsparks » Thu Jun 16, 2016 3:16 pm
Thank you for your assistance, the info you requested is below.
[root@ndevva01 ~]# uname -a
Linux ndevva01 2.6.32-573.26.1.el6.x86_64 #1 SMP Wed May 4 00:57:44 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
[root@ndevva01 ~]# cat /etc/*release
CentOS release 6.7 (Final)
Step 2 Interfaces
Select the ports for which you'd like to monitor bandwidth and port status. You may specify an optional port name to be associated with specific ports.
Port
Check / Uncheck Port Name Max Speed Service Description Bandwidth
Check / Uncheck Port Status
Check / Uncheck
Port 1 GigabitEthernet1/1/1 100.00 Mbps
Port 1
Rate In: Rate Out: Rate In: Rate Out:
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 2 GigabitEthernet1/1/2 1.00 Gbps
Port 2
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 3 GigabitEthernet1/1/3 1.00 Gbps
Port 3
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 4 GigabitEthernet1/1/4 1.00 Gbps
Port 4
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 5 GigabitEthernet1/1/5 1.00 Gbps
Port 5
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 6 GigabitEthernet1/1/6 1.00 Gbps
Port 6
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 7 GigabitEthernet1/1/7 1.00 Gbps
Port 7
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 8 GigabitEthernet1/1/8 100.00 Mbps
Port 8
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 9 GigabitEthernet1/1/9 100.00 Mbps
Port 9
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 10 GigabitEthernet1/1/10 100.00 Mbps
Port 10
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 11 GigabitEthernet1/1/11 100.00 Mbps
Port 11
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 12 GigabitEthernet1/1/12 100.00 Mbps
Port 12
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 13 GigabitEthernet1/1/13 100.00 Mbps
Port 13
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 14 GigabitEthernet1/1/14 1.00 Gbps
Port 14
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 15 GigabitEthernet1/1/15 100.00 Mbps
Port 15
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16 GigabitEthernet1/1/16 100.00 Mbps
Port 16
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 17 GigabitEthernet1/1/17 100.00 Mbps
Port 17
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 18 GigabitEthernet1/1/18 1.00 Gbps
Port 18
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 19 GigabitEthernet1/1/19 100.00 Mbps
Port 19
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 20 GigabitEthernet1/1/20 100.00 Mbps
Port 20
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 21 GigabitEthernet1/1/21 100.00 Mbps
Port 21
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 22 GigabitEthernet1/1/22 100.00 Mbps
Port 22
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 23 GigabitEthernet1/1/23 100.00 Mbps
Port 23
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 24 GigabitEthernet1/1/24 100.00 Mbps
Port 24
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 25 GigabitEthernet1/1/25 100.00 Mbps
Port 25
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 26 GigabitEthernet1/1/26 100.00 Mbps
Port 26
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 27 GigabitEthernet1/1/27 100.00 Mbps
Port 27
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 28 GigabitEthernet1/1/28 100.00 Mbps
Port 28
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 29 GigabitEthernet1/1/29 100.00 Mbps
Port 29
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 30 GigabitEthernet1/1/30 100.00 Mbps
Port 30
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 31 GigabitEthernet1/1/31 100.00 Mbps
Port 31
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 32 GigabitEthernet1/1/32 100.00 Mbps
Port 32
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 33 GigabitEthernet1/1/33 100.00 Mbps
Port 33
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 34 GigabitEthernet1/1/34 100.00 Mbps
Port 34
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 35 GigabitEthernet1/1/35 100.00 Mbps
Port 35
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 36 GigabitEthernet1/1/36 100.00 Mbps
Port 36
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 37 GigabitEthernet1/1/37 100.00 Mbps
Port 37
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 38 GigabitEthernet1/1/38 100.00 Mbps
Port 38
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 39 GigabitEthernet1/1/39 100.00 Mbps
Port 39
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 40 GigabitEthernet1/1/40 100.00 Mbps
Port 40
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 41 GigabitEthernet1/1/41 100.00 Mbps
Port 41
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 42 GigabitEthernet1/1/42 100.00 Mbps
Port 42
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 43 GigabitEthernet1/1/43 100.00 Mbps
Port 43
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 44 GigabitEthernet1/1/44 100.00 Mbps
Port 44
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 45 GigabitEthernet1/1/45 100.00 Mbps
Port 45
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 46 GigabitEthernet1/1/46 100.00 Mbps
Port 46
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 47 GigabitEthernet1/1/47 100.00 Mbps
Port 47
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 48 GigabitEthernet1/1/48 100.00 Mbps
Port 48
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 65 40GigabitEthernet1/2/1 4.29 Gbps
Port 65
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 66 10GigabitEthernet1/2/2 4.29 Gbps
Port 66
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 67 10GigabitEthernet1/2/3 4.29 Gbps
Port 67
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 68 10GigabitEthernet1/2/4 4.29 Gbps
Port 68
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 69 10GigabitEthernet1/2/5 4.29 Gbps
Port 69
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 70 40GigabitEthernet1/2/6 4.29 Gbps
Port 70
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 71 10GigabitEthernet1/2/7 4.29 Gbps
Port 71
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 72 10GigabitEthernet1/2/8 4.29 Gbps
Port 72
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 73 10GigabitEthernet1/2/9 4.29 Gbps
Port 73
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 74 10GigabitEthernet1/2/10 4.29 Gbps
Port 74
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 129 10GigabitEthernet1/3/1 1.00 Gbps
Port 129
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 130 10GigabitEthernet1/3/2 1.00 Gbps
Port 130
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 131 10GigabitEthernet1/3/3 1.00 Gbps
Port 131
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 132 10GigabitEthernet1/3/4 1.00 Gbps
Port 132
Warning:
500.00
500.00
Critical:
800.00
800.00
Port 133 10GigabitEthernet1/3/5 100.00 Mbps
Port 133
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 134 10GigabitEthernet1/3/6 100.00 Mbps
Port 134
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 135 10GigabitEthernet1/3/7 100.00 Mbps
Port 135
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 136 10GigabitEthernet1/3/8 100.00 Mbps
Port 136
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 257 GigabitEthernet2/1/1 100.00 Mbps
Port 257
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 258 GigabitEthernet2/1/2 100.00 Mbps
Port 258
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 259 GigabitEthernet2/1/3 100.00 Mbps
Port 259
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 260 GigabitEthernet2/1/4 100.00 Mbps
Port 260
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 261 GigabitEthernet2/1/5 100.00 Mbps
Port 261
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 262 GigabitEthernet2/1/6 100.00 Mbps
Port 262
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 263 GigabitEthernet2/1/7 100.00 Mbps
Port 263
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 264 GigabitEthernet2/1/8 100.00 Mbps
Port 264
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 265 GigabitEthernet2/1/9 100.00 Mbps
Port 265
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 266 GigabitEthernet2/1/10 100.00 Mbps
Port 266
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 267 GigabitEthernet2/1/11 100.00 Mbps
Port 267
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 268 GigabitEthernet2/1/12 100.00 Mbps
Port 268
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 269 GigabitEthernet2/1/13 100.00 Mbps
Port 269
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 270 GigabitEthernet2/1/14 100.00 Mbps
Port 270
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 271 GigabitEthernet2/1/15 100.00 Mbps
Port 271
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 272 GigabitEthernet2/1/16 100.00 Mbps
Port 272
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 273 GigabitEthernet2/1/17 100.00 Mbps
Port 273
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 274 GigabitEthernet2/1/18 100.00 Mbps
Port 274
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 275 GigabitEthernet2/1/19 100.00 Mbps
Port 275
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 276 GigabitEthernet2/1/20 100.00 Mbps
Port 276
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 277 GigabitEthernet2/1/21 100.00 Mbps
Port 277
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 278 GigabitEthernet2/1/22 100.00 Mbps
Port 278
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 279 GigabitEthernet2/1/23 100.00 Mbps
Port 279
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 280 GigabitEthernet2/1/24 100.00 Mbps
Port 280
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 281 GigabitEthernet2/1/25 100.00 Mbps
Port 281
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 282 GigabitEthernet2/1/26 100.00 Mbps
Port 282
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 283 GigabitEthernet2/1/27 100.00 Mbps
Port 283
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 284 GigabitEthernet2/1/28 100.00 Mbps
Port 284
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 285 GigabitEthernet2/1/29 100.00 Mbps
Port 285
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 286 GigabitEthernet2/1/30 100.00 Mbps
Port 286
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 287 GigabitEthernet2/1/31 100.00 Mbps
Port 287
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 288 GigabitEthernet2/1/32 100.00 Mbps
Port 288
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 289 GigabitEthernet2/1/33 100.00 Mbps
Port 289
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 290 GigabitEthernet2/1/34 100.00 Mbps
Port 290
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 291 GigabitEthernet2/1/35 100.00 Mbps
Port 291
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 292 GigabitEthernet2/1/36 100.00 Mbps
Port 292
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 293 GigabitEthernet2/1/37 100.00 Mbps
Port 293
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 294 GigabitEthernet2/1/38 100.00 Mbps
Port 294
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 295 GigabitEthernet2/1/39 100.00 Mbps
Port 295
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 296 GigabitEthernet2/1/40 100.00 Mbps
Port 296
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 297 GigabitEthernet2/1/41 100.00 Mbps
Port 297
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 298 GigabitEthernet2/1/42 100.00 Mbps
Port 298
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 299 GigabitEthernet2/1/43 100.00 Mbps
Port 299
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 300 GigabitEthernet2/1/44 100.00 Mbps
Port 300
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 301 GigabitEthernet2/1/45 100.00 Mbps
Port 301
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 302 GigabitEthernet2/1/46 100.00 Mbps
Port 302
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 303 GigabitEthernet2/1/47 100.00 Mbps
Port 303
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 304 GigabitEthernet2/1/48 100.00 Mbps
Port 304
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 321 40GigabitEthernet2/2/1 4.29 Gbps
Port 321
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 322 10GigabitEthernet2/2/2 4.29 Gbps
Port 322
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 323 10GigabitEthernet2/2/3 4.29 Gbps
Port 323
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 324 10GigabitEthernet2/2/4 4.29 Gbps
Port 324
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 325 10GigabitEthernet2/2/5 4.29 Gbps
Port 325
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 326 40GigabitEthernet2/2/6 4.29 Gbps
Port 326
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 327 10GigabitEthernet2/2/7 4.29 Gbps
Port 327
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 328 10GigabitEthernet2/2/8 4.29 Gbps
Port 328
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 329 10GigabitEthernet2/2/9 4.29 Gbps
Port 329
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 330 10GigabitEthernet2/2/10 4.29 Gbps
Port 330
Warning:
2.15
2.15
Critical:
3.44
3.44
Port 385 10GigabitEthernet2/3/1 100.00 Mbps
Port 385
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 386 10GigabitEthernet2/3/2 100.00 Mbps
Port 386
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 387 10GigabitEthernet2/3/3 100.00 Mbps
Port 387
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 388 10GigabitEthernet2/3/4 100.00 Mbps
Port 388
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 389 10GigabitEthernet2/3/5 100.00 Mbps
Port 389
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 390 10GigabitEthernet2/3/6 100.00 Mbps
Port 390
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 391 10GigabitEthernet2/3/7 100.00 Mbps
Port 391
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 392 10GigabitEthernet2/3/8 100.00 Mbps
Port 392
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777217 v100 100.00 Mbps
Port 16777217
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777218 v101 100.00 Mbps
Port 16777218
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777219 v102 100.00 Mbps
Port 16777219
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777220 v103 100.00 Mbps
Port 16777220
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777221 v104 100.00 Mbps
Port 16777221
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777222 v106 100.00 Mbps
Port 16777222
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777223 v107 100.00 Mbps
Port 16777223
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777224 v108 100.00 Mbps
Port 16777224
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777225 v109 100.00 Mbps
Port 16777225
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777226 v110 100.00 Mbps
Port 16777226
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777227 v120 100.00 Mbps
Port 16777227
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777228 v130 100.00 Mbps
Port 16777228
Warning:
50.00
50.00
Critical:
80.00
80.00
Port 16777229 v1200 100.00 Mbps
Port 16777229
Warning:
50.00
50.00
Critical:
80.00
80.00
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Thu Jun 16, 2016 4:58 pm
Can you login as root on the XI server and run this command.
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
Then go in to the Xi GUI and Apply the Configuration
Then post the output from the tail command so we can see if there are any errors.
ssax
Dreams In Code
Posts: 7682 Joined: Wed Feb 11, 2015 12:54 pm
Post
by ssax » Thu Jun 16, 2016 5:00 pm
Did you restart httpd after making those
/etc/php.ini changes?
Please answer lmiltchev's other questions:
Also, run this command:
Then run the wizard again and let it spin until you see some type of error in the tail output (you will), then we can adjust from there.
Thank you
bzsparks
Post
by bzsparks » Fri Jun 17, 2016 9:41 am
Yes, I restarted the server after the php.ini changes. I have not been able to add any devices or apply configurations. The info you've requested is below.
tail: /usr/local/nagiosxi/var/cmdsubsys.log: file truncated
PROCESSED 0 COMMANDS
dating password for user nagiosadmin
OUTPUT=
RETURNCODE=0
.........................................tail: /usr/local/nagiosxi/var/cmdsubsys.log: file truncated
PROCESSED 1 COMMANDS
p://localhost/nagiosxi/includes/components/ccm/
CMDLINE
--2016-06-17 09:29:42-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... failed: Name or service not known.
wget: unable to resolve host address “localhost”
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.loginNAGIOSQL LOGIN FAILED!
OUTPUT=/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.loginNAGIOSQL LOGIN FAILED!
RETURNCODE=2
==> /var/log/httpd/error_log <==
--base: Get Device Info on [email protected] :161::::1
--base: Vendor Id: foundry
--base: Populating confcache
--base: Get Interface Info
--base: Walking ifIndex
==> /var/log/httpd/ssl_error_log <==
[Fri Jun 17 09:34:14 2016] [error] [client 10.11.11.65] PHP Notice: Undefined index: tpl in /usr/local/nagiosxi/html/config/monitoringwizard.php on line 967, referer: https://10.10.15.21/nagiosxi/config/monitoringwizard.php
[Fri Jun 17 09:34:17 2016] [error] [client 10.11.11.65] PHP Notice: Undefined index: tpl in /usr/local/nagiosxi/html/config/monitoringwizard.php on line 1371, referer: https://10.10.15.21/nagiosxi/config/monitoringwizard.php
[Fri Jun 17 09:34:23 2016] [error] [client 10.11.11.65] PHP Warning: fopen(/etc/mrtg/conf.d/10.10.100.1.cfg): failed to open stream: No such file or directory in /usr/local/nagiosxi/html/includes/configwizards/switch/switch.inc.php on line 1309, referer: https://10.10.15.21/nagiosxi/config/monitoringwizard.php
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_72.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_72.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_72.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_71.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_71.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_71.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_70.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_70.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_70.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_7.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_7.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_7.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_69.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_69.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_69.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_68.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_68.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_68.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_67.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_67.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_67.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_66.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_66.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_66.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_65.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_65.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_65.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_6.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_6.rrd with '1466174064:742518204:3009444395' opening '/var/lib/mrtg/10.10.254.121_6.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_5.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_5.rrd with '1466174064:546070414:1274792507' opening '/var/lib/mrtg/10.10.254.121_5.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_4.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_4.rrd with '1466174064:3943323847:102924630' opening '/var/lib/mrtg/10.10.254.121_4.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_3.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_3.rrd with '1466174064:1706540661:307505689' opening '/var/lib/mrtg/10.10.254.121_3.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_25.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_25.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_25.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_24.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_24.rrd with '1466174064:353432076:1392575589' opening '/var/lib/mrtg/10.10.254.121_24.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_23.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_23.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_23.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_22.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_22.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_22.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_21.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_21.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_21.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2069.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2069.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2069.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2068.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2068.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2068.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2067.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2067.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2067.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2066.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2066.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2066.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2065.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2065.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2065.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2064.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2064.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2064.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2063.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2063.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2063.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2062.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2062.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2062.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2061.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2061.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2061.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2060.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2060.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2060.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2059.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2059.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2059.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2058.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2058.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2058.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2057.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2057.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2057.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2056.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2056.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2056.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2055.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2055.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2055.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2054.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2054.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2054.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2053.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2053.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2053.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2052.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2052.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2052.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2051.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2051.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2051.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2050.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2050.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2050.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2049.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2049.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_2049.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_20.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_20.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_20.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_2.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_2.rrd with '1466174064:183156691:14878593' opening '/var/lib/mrtg/10.10.254.121_2.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_19.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_19.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_19.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_18.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_18.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_18.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_17.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_17.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_17.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_16.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_16.rrd with '1466174064:75992469:341311117' opening '/var/lib/mrtg/10.10.254.121_16.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_15.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_15.rrd with '1466174064:1219358201:3909356554' opening '/var/lib/mrtg/10.10.254.121_15.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_14.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_14.rrd with '1466174064:3840917529:3503026741' opening '/var/lib/mrtg/10.10.254.121_14.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_136.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_136.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_136.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_135.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_135.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_135.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_134.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_134.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_134.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_133.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_133.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_133.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_132.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_132.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_132.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_131.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_131.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_131.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_130.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_130.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_130.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_13.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_13.rrd with '1466174064:99236879:3698601608' opening '/var/lib/mrtg/10.10.254.121_13.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_129.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_129.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_129.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_12.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_12.rrd with '1466174064:720712030:4284659287' opening '/var/lib/mrtg/10.10.254.121_12.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_11.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_11.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_11.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_10.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_10.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.254.121_10.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.254.121_1.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.254.121_1.rrd with '1466174064:1916634705:551478477' opening '/var/lib/mrtg/10.10.254.121_1.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_9.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_9.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_9.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_8.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_8.rrd with '1466174064:75005482:104309893' opening '/var/lib/mrtg/10.10.100.1_8.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_74.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_74.rrd with '1466174064:197827953:409203512' opening '/var/lib/mrtg/10.10.100.1_74.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_73.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_73.rrd with '1466174064:1774879177:2828625545' opening '/var/lib/mrtg/10.10.100.1_73.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_72.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_72.rrd with '1466174064:236150302:753484225' opening '/var/lib/mrtg/10.10.100.1_72.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_71.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_71.rrd with '1466174064:267856993:543098082' opening '/var/lib/mrtg/10.10.100.1_71.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_70.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_70.rrd with '1466174064:1832578344:3653376925' opening '/var/lib/mrtg/10.10.100.1_70.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_7.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_7.rrd with '1466174064:858808272:1116768791' opening '/var/lib/mrtg/10.10.100.1_7.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_69.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_69.rrd with '1466174064:105335906:212730603' opening '/var/lib/mrtg/10.10.100.1_69.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_68.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_68.rrd with '1466174064:66087496:955463512' opening '/var/lib/mrtg/10.10.100.1_68.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_67.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_67.rrd with '1466174064:88277575:411719899' opening '/var/lib/mrtg/10.10.100.1_67.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_66.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_66.rrd with '1466174064:75465661:261693742' opening '/var/lib/mrtg/10.10.100.1_66.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_65.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_65.rrd with '1466174064:320135090:566621992' opening '/var/lib/mrtg/10.10.100.1_65.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_6.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_6.rrd with '1466174064:441875557:329936078' opening '/var/lib/mrtg/10.10.100.1_6.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_5.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_5.rrd with '1466174065:961784675:414109411' opening '/var/lib/mrtg/10.10.100.1_5.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_48.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_48.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_48.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_47.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_47.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_47.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_46.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_46.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_46.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_45.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_45.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_45.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_44.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_44.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_44.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_43.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_43.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_43.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_42.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_42.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_42.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_41.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_41.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_41.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_40.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_40.rrd with '1466174065:74929874:104624767' opening '/var/lib/mrtg/10.10.100.1_40.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_4.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_4.rrd with '1466174065:35987529:3698794143' opening '/var/lib/mrtg/10.10.100.1_4.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_392.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_392.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_392.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_391.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_391.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_391.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_390.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_390.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_390.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_39.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_39.rrd with '1466174065:15938541:154813238' opening '/var/lib/mrtg/10.10.100.1_39.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_389.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_389.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_389.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_388.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_388.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_388.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_387.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_387.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_387.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_386.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_386.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_386.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_385.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_385.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_385.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_38.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_38.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_38.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_37.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_37.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_37.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_36.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_36.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_36.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_35.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_35.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_35.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_34.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_34.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_34.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_330.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_330.rrd with '1466174065:212731187:105336050' opening '/var/lib/mrtg/10.10.100.1_330.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_33.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_33.rrd with '1466174065:0:0' opening '/var/lib/mrtg/10.10.100.1_33.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_329.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_329.rrd with '1466174065:955548762:66087496' opening '/var/lib/mrtg/10.10.100.1_329.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_328.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_328.rrd with '1466174064:411720347:88277575' opening '/var/lib/mrtg/10.10.100.1_328.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_327.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_327.rrd with '1466174064:261693982:75465661' opening '/var/lib/mrtg/10.10.100.1_327.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_326.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_326.rrd with '1466174064:566621628:320134510' opening '/var/lib/mrtg/10.10.100.1_326.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_325.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_325.rrd with '1466174064:409203512:197827953' opening '/var/lib/mrtg/10.10.100.1_325.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_324.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_324.rrd with '1466174064:2828627103:1774896629' opening '/var/lib/mrtg/10.10.100.1_324.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_323.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_323.rrd with '1466174064:753484433:236150542' opening '/var/lib/mrtg/10.10.100.1_323.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_322.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_322.rrd with '1466174064:543098082:267857233' opening '/var/lib/mrtg/10.10.100.1_322.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_321.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_321.rrd with '1466174064:3653373927:1832577832' opening '/var/lib/mrtg/10.10.100.1_321.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_32.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_32.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_32.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_31.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_31.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_31.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_304.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_304.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_304.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_303.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_303.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_303.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_302.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_302.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_302.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_301.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_301.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_301.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_300.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_300.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_300.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_30.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_30.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_30.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_3.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_3.rrd with '1466174064:2739308001:1657119222' opening '/var/lib/mrtg/10.10.100.1_3.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_299.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_299.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_299.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_298.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_298.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_298.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_297.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_297.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_297.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_296.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_296.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_296.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_295.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_295.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_295.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_294.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_294.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_294.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_293.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_293.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_293.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_292.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_292.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_292.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_291.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_291.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_291.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_290.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_290.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_290.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_29.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_29.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_29.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_289.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_289.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_289.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_288.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_288.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_288.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_287.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_287.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_287.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_286.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_286.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_286.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_285.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_285.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_285.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_284.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_284.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_284.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_283.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_283.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_283.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_282.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_282.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_282.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_281.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_281.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_281.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_280.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_280.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_280.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_28.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_28.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_28.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_279.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_279.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_279.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_278.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_278.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_278.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_277.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_277.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_277.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_276.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_276.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_276.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_275.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_275.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_275.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_274.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_274.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_274.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_273.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_273.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_273.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_272.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_272.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_272.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_271.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_271.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_271.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_270.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_270.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_270.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_27.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_27.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_27.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_269.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_269.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_269.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_268.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_268.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_268.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_267.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_267.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_267.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_266.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_266.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_266.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_265.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_265.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_265.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_264.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_264.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_264.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_263.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_263.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_263.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_262.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_262.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_262.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_261.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_261.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_261.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_260.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_260.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_260.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_26.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_26.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_26.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_259.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_259.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_259.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_258.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_258.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_258.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_257.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_257.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_257.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_25.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_25.rrd with '1466174064:78415809:2303381564' opening '/var/lib/mrtg/10.10.100.1_25.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_24.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_24.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_24.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_23.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_23.rrd with '1466174064:1863254098:3797451887' opening '/var/lib/mrtg/10.10.100.1_23.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_22.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_22.rrd with '1466174064:3357212246:2398037665' opening '/var/lib/mrtg/10.10.100.1_22.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_21.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_21.rrd with '1466174064:2172120682:3915956114' opening '/var/lib/mrtg/10.10.100.1_21.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_20.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_20.rrd with '1466174064:1601573029:2356817453' opening '/var/lib/mrtg/10.10.100.1_20.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_2.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_2.rrd with '1466174064:1002883983:560159206' opening '/var/lib/mrtg/10.10.100.1_2.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_19.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_19.rrd with '1466174064:243469252:3863188557' opening '/var/lib/mrtg/10.10.100.1_19.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_18.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_18.rrd with '1466174064:140780914:177570673' opening '/var/lib/mrtg/10.10.100.1_18.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_17.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_17.rrd with '1466174064:13075198:76099628' opening '/var/lib/mrtg/10.10.100.1_17.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777229.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777229.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777229.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777228.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777228.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777228.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777227.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777227.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777227.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777226.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777226.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777226.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777225.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777225.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777225.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777224.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777224.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777224.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777223.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777223.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777223.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777222.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777222.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777222.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777221.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777221.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777221.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777220.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777220.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777220.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777219.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777219.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777219.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777218.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777218.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777218.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16777217.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16777217.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_16777217.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_16.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_16.rrd with '1466174064:13254519:76167686' opening '/var/lib/mrtg/10.10.100.1_16.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_15.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_15.rrd with '1466174064:13121545:76255984' opening '/var/lib/mrtg/10.10.100.1_15.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_14.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_14.rrd with '1466174064:766332485:4125159968' opening '/var/lib/mrtg/10.10.100.1_14.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_136.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_136.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_136.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_135.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_135.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_135.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_134.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_134.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_134.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_133.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_133.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_133.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_132.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_132.rrd with '1466174064:1259919150:988919773' opening '/var/lib/mrtg/10.10.100.1_132.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_131.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_131.rrd with '1466174064:2004226283:3940865949' opening '/var/lib/mrtg/10.10.100.1_131.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_130.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_130.rrd with '1466174064:4117402095:1401702790' opening '/var/lib/mrtg/10.10.100.1_130.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_13.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_13.rrd with '1466174064:42985708:2103014278' opening '/var/lib/mrtg/10.10.100.1_13.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_129.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_129.rrd with '1466174064:3965451460:2718455948' opening '/var/lib/mrtg/10.10.100.1_129.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_12.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_12.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_12.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_11.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_11.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_11.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_10.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_10.rrd with '1466174064:0:0' opening '/var/lib/mrtg/10.10.100.1_10.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot tune logfile: opening '/var/lib/mrtg/10.10.100.1_1.rrd': Permission denied
2016-06-17 09:34:25: ERROR: Cannot update /var/lib/mrtg/10.10.100.1_1.rrd with '1466174064:1075358436:547256685' opening '/var/lib/mrtg/10.10.100.1_1.rrd': Permission denied
[Fri Jun 17 09:34:25 2016] [error] [client 10.11.11.65] PHP Notice: Undefined index: skip_reconfigure in /usr/local/nagiosxi/html/config/monitoringwizard.php on line 2230, referer: https://10.10.15.21/nagiosxi/config/monitoringwizard.ph
bzsparks
Posts: 6 Joined: Tue Jun 14, 2016 5:07 pm
Post
by bzsparks » Fri Jun 17, 2016 9:52 am
So after seeing that localhost was not being resolved I added it to the hosts file and performed another import and it worked successfully.
Is there anything else I should be concerned about? Any thoughts on why localhost was not initially in the hosts file?
Thank you for your assistance.
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Fri Jun 17, 2016 12:52 pm
Ah! It was the /etc/hosts file! Just coming back to this thread and I see this now.
As for why it wasn't added, I'm not sure why it wasn't able to resolve itself. By default, XI doesn't make any changes to the /etc/hosts file. Was this an OVA install or did you install it manually?
