Compile 64-bit on SPARC produces LD error
dheitepriem
Post by dheitepriem »
Hi everyone,
I'm trying to compile the 64-bit version of Nagios 4.1.1 on Solaris 11.3 SPARC and getting the following errors:
gmake[1]: Entering directory `/export/home/dheitepriem/nagios/nagios-4.1.1/module'
gcc -m64 -I..  -m64 -DHAVE_CONFIG_H -o helloworld.o helloworld.c -G -m64 -lsocket
ld: fatal: relocation error: R_SPARC_H44: file /var/tmp//ccl5aiPv.o: symbol helloworld_module_handle: relocations based on the ABS44 coding model can not be used in building a shared object
ld: fatal: relocation error: R_SPARC_M44: file /var/tmp//ccl5aiPv.o: symbol helloworld_module_handle: relocations based on the ABS44 coding model can not be used in building a shared object
ld: fatal: relocation error: R_SPARC_L44: file /var/tmp//ccl5aiPv.o: symbol helloworld_module_handle: relocations based on the ABS44 coding model can not be used in building a shared object
ld: fatal: relocation error: R_SPARC_H44: file /var/tmp//ccl5aiPv.o: symbol .rodata (section): relocations based on the ABS44 coding model can not be used in building a shared object
ld: fatal: relocation error: R_SPARC_M44: file /var/tmp//ccl5aiPv.o: symbol .rodata (section): relocations based on the ABS44 coding model can not be used in building a shared object
ld: fatal: relocation error: R_SPARC_L44: file /var/tmp//ccl5aiPv.o: symbol .rodata (section): relocations based on the ABS44 coding model can not be used in building a shared object
ld: fatal: symbol referencing errors
collect2: error: ld returned 1 exit status
gmake[1]: *** [helloworld.o] Error 1
gmake[1]: Leaving directory `/export/home/dheitepriem/nagios/nagios-4.1.1/module'
gmake: *** [all] Error 2
Here are my "configure" and "make" commands:
CFLAGS="-m64" CC="gcc -m64" LD="ldd -m64" LDFLAGS="-m64" CXXFLAGS="-m64" ./configure --prefix=/opt/nagios --with-nagios-user=nagios --with-nagios-group=nagios --with-command-user=nagios --with-command-group=nagios
CFLAGS="-m64" CC="gcc -m64" LD="ldd -m64" LDFLAGS="-m64" CXXFLAGS="-m64" /usr/bin/gmake all
Attached are also my config.log and config.status files.
Thank you very much in advance.
config.status.txt
(30.92 KiB) Downloaded 399 times
config.log
(75.42 KiB) Downloaded 382 times
Best regards,
Daniel Heitepriem
dheitepriem
Re: Compile 64-bit on SPARC produces LD error
Just a quick note: As the error appears when building the "hello world" module, I did just check if it was really necessary. As this is a simple example for modules I considered it not necessary for us and added a simple "#" to the appropriate lines in the main MakeFile (*nagios-4.1.1-dir*/Makefile).
After this the modules folder wasn't touched anymore and everything worked as it should. Nevertheless it would be nice if this could be investigated further as a proper building process without any manual editing is always nicer than choosing the solution I did ;)
Best regards,
Daniel Heitepriem
Can you post this on our GitHub page for Core?
https://github.com/NagiosEnterprises/nagioscore
That'll get visibility to our developers right away.
dheitepriem
I posted the error to the github page (https://github.com/NagiosEnterprises/na ... issues/135) so I think this topic can be closed.
Best regards,
Daniel Heitepriem
Awesome, thanks!
