Nagios is active on CLI but not running on Web Interface
vincdpt
Post by vincdpt »
Good morning,
I have a problem with my Nagios configuration. This is the response of service nagios status :
 root@SRV-SUPERVISION-BT:~# service nagios status -l
● nagios.service - LSB: Starts and stops the Nagios monitoring server
   Loaded: loaded (/etc/init.d/nagios)
   Active: active (running) since ven. 2016-06-17 09:47:46 CEST; 41min ago
  Process: 458 ExecStart=/etc/init.d/nagios start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/nagios.service
           ├─533 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios...
           ├─553 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/...
           ├─555 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/...
           ├─556 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/...
           ├─558 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/...
           ├─559 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/...
           ├─560 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/...
           └─623 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios...
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: nerd: Channel opathchecks r...y
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: nerd: Fully initialized and...!
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Successfully registe...r
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Registry request: na...3
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Registry request: na...8
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Registry request: na...9
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Registry request: na...6
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Registry request: na...0
juin 17 09:47:46 SRV-SUPERVISION-BT nagios[533]: wproc: Registry request: na...5
juin 17 09:47:48 SRV-SUPERVISION-BT nagios[533]: Successfully launched comma...3
Hint: Some lines were ellipsized, use -l to show in full.
But when I'm going on the web interface, Nagios Core is not running :
The configtest command is also right :
root@SRV-SUPERVISION-BT:~# service nagios configtest
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
    Checked 8 services.
    Checked 1 hosts.
    Checked 1 host groups.
    Checked 0 service groups.
    Checked 1 contacts.
    Checked 1 contact groups.
    Checked 24 commands.
    Checked 5 time periods.
    Checked 0 host escalations.
    Checked 1 hosts
    Checked 0 host dependencies
    Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
Object precache file created:
/usr/local/nagios/var/objects.precache
Also, this is the right on /usr/local/nagios/var :
root@SRV-SUPERVISION-BT:/usr/local/nagios/bin# ls /usr/local/nagios/var -l
total 88
drwxrwsr-x 2 nagios nagios  4096 juin  16 23:59 archives
-rw-r--r-- 1 nagios nagios    34 juin  17 11:00 nagios.configtest
-rw-r--r-- 1 nagios nagios     4 juin  17 09:47 nagios.lock
-rw-r--r-- 1 nagios nagios  3007 juin  17 10:47 nagios.log
-rw-r--r-- 1 nagios nagios 12665 juin  17 09:47 objects.cache
-rw-r--r-- 1 nagios nagios 12665 juin  17 11:00 objects.precache
-rw------- 1 nagios nagios 13062 juin  17 10:47 retention.dat
drwxrwsr-x 2 nagios nagcmd  4096 juin  17 09:47 rw
drwxr-sr-x 3 root   nagios  4096 juin   3 08:28 spool
-rw-rw-r-- 1 nagios nagios 13485 juin  17 11:26 status.dat
I'm on Debian,it's a fresh install and I do not understand the problem. If anyone can help me, thanks in advance.
Re: Nagios is active on CLI but not running on Web Interface
What version of Debian are you running? How did you install nagios? What guide/document did you follow?
I am not able to recreate the issue. I installed nagios on Debian 8.
root@debian:/tmp/nagios-plugins-2.1.1# uname -a
Linux debian 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) x86_64 GNU/Linux
root@debian:/tmp/nagios-plugins-2.1.1# cat /etc/*release
PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
NAME="Debian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=debian
HOME_URL="http://www.debian.org/"
SUPPORT_URL="http://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
I followed the guide below:
http://www.miloszengel.com/nagios-core- ... -x-jessie/
After this, I had to perform a few additional steps:
cp /etc/init.d/skeleton /etc/init.d/nagios
Added the following lines to "/etc/init.d/nagios":
DESC="Nagios"
NAME=nagios
DAEMON=/usr/local/nagios/bin/$NAME
DAEMON_ARGS="-d /usr/local/nagios/etc/nagios.cfg"
PIDFILE=/usr/local/nagios/var/$NAME.lock
Started nagios:
vincdpt
Post by vincdpt »
Hello, thank you for you'r response. My version of debian is :
root@SRV-SUPERVISION-BT:~# uname -a
Linux SRV-SUPERVISION-BT 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) x86_64 GNU/Linux
[1]+  Termine 1               uname -
I have followed this tutorial : http://djibril.developpez.com/tutoriels ... nt/#LIII-A to the third part (III) because after I need a working nagios web-interface.
If I want to follow your tutorial, how I can delete my actual installation ?
As @lmiltchev mentioned, he was able to do this fine on Debian 8. I would follow the above instructions, on a clean, minimal version of Debian 8. It's hard to say what has been done, which is why I would advise against trying to re-install over it and spin up a clean machine.
Let us know if you have further questions about the install.
