mod_gearman worker error
delboy1966
Post by delboy1966 »
I am running the following
Nagios 4.1.1
mod_gearman-1.4_nagios4-1.el6.x86_64
gearmand-server-0.25-1.x86_64
I have 5 gearman workder nodes do the checks from Nagios.
And everyday I'm getting this in the output of a lot of checks:
service check orphaned, is the mod-gearman worker on queue 'service' running?
I find that restarting the workers on the worker nodes clears it.
But would prefer to find and resolve the cause.
I did see another thread suggesting changing:
use_retained_scheduling_info=0
In the nagios.cfg file, which I did but this hasn't cured it.
Has anyone seen or had this before?
Tony
Re: mod_gearman worker error
Have you tried to upgrade to the latest version of mod_gearman to see if that fixes the issue?
The changelog says there are some file / memory leaks that could cause the issue you are having.
https://github.com/sni/mod_gearman/blob/master/Changes
delboy1966
Sorry for the delay in responding back to update on your suggestion.
I did eventually upgrade to the latest version and the problem seems to have been resolved.
Thanks for your help.
Happy for this to be marked as resolved now.
Tony
