group by combined fields?
_asp_
Post by _asp_ »
I have follwoing fields in my events:
processingTime: float - time the service took to return
serviceCall: string - Name of the service which was called
serviceCallSub: string - subroutine / parameter of the service which was called.
Now if I want to know which serviceCalls are have the highest processing time in sum, to find out which are the most expensive ones I can do that by using a term_stats panel. So far so good.
But know I would like to go one level deeper, to see which serviceCall+serviceCallSub-combination is the most expensive one.
Is it possible to "create virtual fields" (combination / concatenation of multiple fields) on which I can use term_stats panel?
The only workaround I found is to concat the needed fields in logstash, but then it is only accessible for new indexes after the logstash parsing have been updated. If I could do so in kibana / elasticsearch I would be much more flexible.
Andreas
hsmith
Agent Smith
Re: group by combined fields?
Post by hsmith »
This is not something I've had the need to do yet, but I blieve the manner you want to do this in would either have to be done in logstash when the logs are first coming in using a grok filter, or you might be able to come up with some query magic. Perhaps have a read of this: https://www.elastic.co/guide/en/elastic ... earch.html
Former Nagios Employee.
me.
