Inter server communication monitoring
sify_nagios
Post by sify_nagios »
Hi Team,
I would like to monitor whether port 443 is listening between the Server A and Server B.
If i would configure 443 TCP port check from Nagios, it would be Server C checking port availability with Server B.
Instead of that i would like to know whether port communication between Two servers are fine or not.
Note : Requirement comes in cross platform (Linux, Windows)
Please let me know if my requirement is not clear.
Rgds
Srini
Re: Inter server communication monitoring
You can use check_by_ssh or check_nrpe to execute check_http on either Server A or Server B, which would then check the reciprocal.
This document is for monitoring by SSH - https://assets.nagios.com/downloads/nag ... ng_SSH.pdf
See this one for using NRPE - https://assets.nagios.com/downloads/nag ... g_NRPE.pdf
Here's the file that contains the current check_http from Nagios plugins 2.1.1. You'll still need to compile it. - http://www.nagios-plugins.org/download/ ... 1.1.tar.gz
sify_nagios
Sorry i may not be clear to you. I don't wanna monitor the port availability from nagios.
Consider below scenario.
APP SERVER in my infra is SERVER A.
DB SERVER = SERVER B.
Nagios server called SERVER C.
From SERVER C i wanna poll either SERVER A or SERVER B to identified port(22 or 23) communication between SERVER A and SERVER B is happening or not.
Hope i am clear to you this time.
Note : Port numbers are only example. We may check different ports.
Kindly guide us to achieve above.
Rgds
Srini
Got it, you'll still need to use an agent such as NRPE or check_by_ssh so the same links apply.
As for checking the connection, if you run netstat -an on SERVER A or SERVER B, will it show the connection as established?
You should be able to use this plugin I wrote to accomplish checking the established ports. https://raw.githubusercontent.com/rckna ... netstat.sh
[root@localhost libexec]# netstat -an | grep :22
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0     64 192.168.4.179:22        192.168.5.47:50684      ESTABLISHED
tcp        0      0 192.168.4.179:22        192.168.5.47:64061      ESTABLISHED
tcp6       0      0 :::22                   :::*                    LISTEN
[root@localhost libexec]# netstat -an | grep :22 | grep 'ESTABLISHED'
[root@localhost libexec]# netstat -an | grep :22 | grep 'ESTABLISHED' | wc -l
2
The plugin as is, doesn't care if they are established or not. So you'll need to modify line 49 to this -
count=$($netstat -an | grep :$port | grep 'ESTABLISHED' | wc -l)
sify_nagios
Hi Team,
Achieved the same by writing two lines of simple code.
Works simple and efficient.
Attached file and steps for same (to newbies like me :D )
Steps:
Step 1 : Place the file in the below mentioned path of client server(SERVER_A).
/usr/local/nagios/libexec
Note : Please make sure the file has nagios user to execute permission.
Step 2 : Please append the below command in the respective config file.
File path : /usr/local/nagios/etc/nrpe/common.cfg
command[check_net]=/usr/local/nagios/libexec/check_net.sh $ARG1$
Step 3 : Now check from nagios server by following command.
/usr/local/nagios/libexec/check_nrpe -h SERVER_A -c check_ntp -p PORT_NUMBER -d SERVER_B
Thanks for your support.
Rgds
Srini
@sify_nagios Thanks for sharing! Is it all right if we lock this thread?
