I recently added an Ubuntu server to my NagiosXI. I followed the standard procedure that has always worked for me in the past. This server is giving me an error on the CPU check, see attachment, but all the other services are checking properly. Please assist.
Thanks.
NRPE Ubuntu CPU check error
Re: NRPE Ubuntu CPU check error
Did you run through this common solutions document?
https://assets.nagios.com/downloads/nag ... utions.pdf
Usually this is because Ubuntu is using dash instead of bash. Check out the "The wrong interpreter is used when running the remote plugin" section and see if that offers any help.
