Log files / indexes after reboot
CFT6Server
Post by CFT6Server »
I had a previous thread where a Log server node is reading from apache logs, but everytime the node is rebooted, it basically reads and reopen indexes, which causes thousands of shards to be created.
https://support.nagios.com/forum/viewto ... &hilit=log
Any suggestions on how to stop this from happening?
You can see large number of shards opening and being unassigned.
[root@2n3 ~]# curl localhost:9200/_cluster/health?pretty
  "cluster_name" : "80e9022e-f73f-429e-8927-f23d0d88dfd2",
  "status" : "red",
  "timed_out" : false,
  "number_of_nodes" : 6,
  "number_of_data_nodes" : 6,
  "active_primary_shards" : 3262,
  "active_shards" : 3780,
  "relocating_shards" : 0,
  "initializing_shards" : 35,
  "unassigned_shards" : 3707,
  "number_of_pending_tasks" : 46049,
  "number_of_in_flight_fetch" : 0
  "status" : "red",
  "active_primary_shards" : 4096,
  "active_shards" : 4624,
  "initializing_shards" : 32,
  "unassigned_shards" : 3576,
  "number_of_pending_tasks" : 64596,
  "status" : "red",
  "number_of_pending_tasks" : 64609,
hsmith
Agent Smith
Re: Log files / indexes after reboot
Post by hsmith »
For clarity, every time the NLS node is rebooted, or every time your apache server is rebooted? Or is your NLS reading the local apache log?
Former Nagios Employee.
me.
CFT6Server
Everytime the log server is rebooted and it is reading apache logs from a NFS share where the logs reside.
hsmith
Agent Smith
Post by hsmith »
Can I see the input you're using to do this?
me.
