Upgrade Failing Due to Space Constraints
CarlWedu
Post by CarlWedu »
our /usr/local/nagiosna/var/backend.log file is taking up alot of space on our server and our upgrade of the box is failing due to space constraints. recommendations for rectifying? thanks!
-rw-rw-r--+ 1 nna nnacmd 686137344 Jun 22 12:21 backend.log
# ./upgrade
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Could not get metalink https://mirrors.fedoraproject.org/metal ... rch=x86_64 error was
14: problem making ssl connection
* base: mirror.cs.pitt.edu
* epel: mirror.cs.pitt.edu
* extras: repo1.ash.innoscale.net
* updates: mirror.cs.pitt.edu
extras | 3.4 kB 00:00
Traceback (most recent call last):
File "/usr/lib/python2.6/site-packages/urlgrabber/grabber.py", line 1097, in _retrieve
self.fo.write(buf)
IOError: [Errno 28] No space left on device
Current download cancelled, interrupt (ctrl-c) again within two seconds
to exit.
self.fo.write(buf)
Re: Upgrade Failing Due to Space Constraints
You can delete the backend.log file to free up space on your system so you can upgrade it.
FYI, the log file was fixed in version Network Analyzer version 2R1.0 released on 03/04/2015 log rotations were added so upgrading should fix it for you.
Added daily log rotation for backend.log and 7 days to be kept -JO
CarlWedu
Post by CarlWedu »
thank you!!
/resolve
Post by mcapra »
Closing this and marking as resolved
